[Solved] Get some error and my portal page will garbled
Current Version: 2.0.2
Released: 2013-10-27
wang5555
Translator
phpBB.com User: wang5555
Post by wang5555 »
If I enabled "GLOBAL_ANNOUNCEMENTS" or "LATEST_NEWS" module, I get some error messages following.
And my portal page will garbled.
[phpBB Debug] PHP Notice: in file [ROOT]/portal/includes/functions.php on line 679: Undefined variable: global_announce_list
[phpBB Debug] PHP Notice: in file [ROOT]/portal/includes/functions.php on line 696: Undefined variable: global_announce_list
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4803: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3839)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4805: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3839)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4806: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3839)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4807: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3839)
p.s.
Now my forum (the PHP is v5.4.3) disabled "GLOBAL_ANNOUNCEMENTS" and "LATEST_NEWS" modules.
The another forum had the same issue.
It is more blessed to give than to reveive, welcome to letter, thanks & good-bye!
Good luck ^_^
Welcome to visit my forum!!
https://wang5555.dnsfor.me/phpBB3/
p.s. Shut down computer before 11 clock night!!!
Re: Get some error and my portal page will garbled
Have they done that?:
Update B3P v.1.0.6 to B3P v.2.0.0b1
Delete files
Delete adm/style/acp_portal.html
Delete language/en/mods/additional_blocks.php
Delete language/en/mods/info_acp_additional_blocks.php
Delete language/en/mods/install_portal.php
Delete language/en/mods/lang_portal.php
Delete language/en/mods/lang_portal_acp.php
Delete portal/block/*.*
Delete styles/prosilver/template/portal/portal_center.html
Delete styles/prosilver/template/portal/portal_left.html
Delete styles/prosilver/template/portal/portal_right.html
Delete styles/prosilver/template/portal/block/*.*
Delete styles/prosilver/theme/images/portal/mini_cal_icon_left_arrow.png
Delete styles/prosilver/theme/images/portal/mini_cal_icon_right_arrow.png
Delete styles/prosilver/theme/images/portal/portal_login.png
Delete styles/prosilver/theme/images/portal/portal_minical.png
Delete styles/prosilver/theme/images/portal/portal_random.png
Delete styles/prosilver/theme/images/portal/portal_stats.png
UpdateB3P v.2.0.0b1 to B3P v.2.0.0
Delete files
Delete portal/includes/trim_message/*.*
Delete styles/prosilver/template/portal/modules/announcements.html
Delete styles/prosilver/template/portal/modules/announcements_compact.html
All cache emptied?
wang5555
Translator
Post by wang5555 »
archivar wrote:Have they done that?:
Delete files
Delete files
Thanks for your reply.
My forum updated B3P from v1.0.6 to v2.0.0
I am sure "Delete files" by refer "contrib/update_106_to_200/update.xml".
And completely purge the cache.
Good luck ^_^
Do they also ask if they can translate Googl able in their language. ==> /knowledge/kb_show.php?id=60
Unfortunately I can not translate correctly. :oops:
wang5555
Translator
Post by wang5555 »
archivar wrote:Do they also ask if they can translate Googl able in their language. ==> /knowledge/kb_show.php?id=60
Thanks for your help.
I think this file "/portal/includes/functions.php" maybe had some bug.
So cause of this "Undefined variable: global_announce_list" error.
Good luck ^_^
It may be, they have code-snippets in files of old add-ons portal and / or access from the old portal remove. Errors can not show always you the exact path.
I'm currently taking a look at it.
wang5555
Translator
Post by wang5555 »
I already fix this bug.
Share my modified method:
--OPEN--
--FIND--
	$last_read = $topic_ids = $forum_ids = $tracking_info = $rev_forum_ids = array();
--REPLACE WITH--
	$last_read = $topic_ids = $forum_ids = $tracking_info = $rev_forum_ids = $global_announce_list = array();
--SAVE & CLOSE--
Good luck ^_^
Re: [Solved] Get some error and my portal page will garbled
Thank you for your input.
This has been fixed in our repository:
https://github.com/board3/Board3-Portal ... f71bab3db4
ixl
Sponsor
phpBB.de User: IXL
phpBB.com User: IXLUKCOM
Post by ixl »
Can I ask, if this fix is included in the latest download please?
I.X.L
Just because it worked for you, doesnt mean it's right. ;)
http://WWW.TEAMGAMERS.CO.UK
