Welcome Message and IE9 Compatabilty
Re: Welcome Message and IE9 Compatabilty
ixl
Topic author - Sponsor
- phpBB.de User: IXL
- phpBB.com User: IXLUKCOM
Strange the poll works fine in IE8, Google Chrome, Safari and Firefox in the left or right columns.
Just not in IE9.
Its not just the block spaces that are the problem.
Hmm. I wonder how I can fix.
Thank you all for your help so far.
IXL
Just not in IE9.
IXL
Easy to fix: Get rid of IE9.
I can agree.Marc wrote:Easy to fix: Get rid of IE9.
The IE9 on PC with 64 bit system causing problems in the forum with the Adobe Flash Player.
ixl
LOL
Unfortunately, its not me you have to convince.
It's 68% of our users on our site use IE9.
I'm still unsure even if it is IE9, is it the themes that are not right or is it the portal, or is really IE9.
If you think carefully what I put, why does the prosilver vote work in IE9 but not ca_black? Its very odd. Could someone please verify if they have the same problem and my issue is not an isolated problem?
( PS, I use IE9 at home but have no issues with flashplayer - since latest update )
The problem is IE9 with the prosilver and all styles prosilver based.
ixl
I'll try to find a sub silver theme that's similar to ca-black instead.
If I find one that works, that's not in your released section I'll let you know.
Thanks everyone for your help though. It seems as if this is a problem that just cannot be fixed.
. . . . But I do love your portal.
ixl
No luck so far.
