Artodia: Helion (Base: prosilver)
Style: Artodia: Helion
Style Version: 1.2.0
Style Download: http://www.phpbb.com/customise/db/style/artodia_helion/
to: root/styles/art_helion/template/portal/*.*
to: root/styles/art_helion/theme/portal.css
to: root/styles/art_helion/theme/images/portal/*.*
open: root/styles/art_helion/template/_menu.html
<li class="menu-item menu-home<!-- IF SCRIPT_NAME == 'index' and not .navlinks --> active<!-- ENDIF -->"><a href="{U_INDEX}">{L_INDEX}</a></li>
<!-- IF U_PORTAL --><li class="menu-item menu-home<!-- IF SCRIPT_NAME == 'index' and not .navlinks --> active<!-- ENDIF -->"><a href="{U_PORTAL}">{L_PORTAL}</a></li><!-- ENDIF -->
open: root/styles/art_helion/template/overall_footer.html
<!-- INCLUDE _sidebar_right.html -->
open: root/styles/art_helion/template/overall_header.html
<div class="popup-trigger">
<!-- INCLUDE _top.html -->
<div class="layout-outer">
<div class="forum-wrapper">
<div class="layout-wrapper">
<div class="layout-middle page-content">
					<a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}<!-- IF PRIVATE_MESSAGE_INFO_UNREAD -->, {PRIVATE_MESSAGE_INFO_UNREAD}<!-- ENDIF --></a>
open: root/styles/art_helion/template/portal/modules/announcements_center_compact.html
{$CC_BLOCK_H_L}
{$CC_BLOCK_H_R}
{$CC_BLOCK_H_L}
	<dt>{$TITLE}</dt>
{$CC_BLOCK_H_R}
open: root/styles/art_helion/template/portal/modules/news_compact_center.html
{$CC_BLOCK_H_L}
{$CC_BLOCK_H_R}
{$CC_BLOCK_H_L}
	<dt>{$TITLE}</dt>
{$CC_BLOCK_H_R}
open: root/styles/art_helion/theme/stylesheet.css
open: root/styles/art_helion/template/portal/_block_config.html
<!-- DEFINE $LR_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl><dt style="padding: 0px 0px 2px; white-space: nowrap; margin-bottom: 0px; margin-top: 0px;">' -->
<!-- DEFINE $LR_BLOCK_F_R = '<span class="corners-bottom"><span></span></span></div></div>' -->
<!-- DEFINE $C_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl class="icon"><dt>' -->
<!-- DEFINE $C_BLOCK_F_R = '<span class="corners-bottom"><span></span></span></div></div>' -->
<!-- DEFINE $CC_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl class="icon">' -->
nach: root/styles/art_helion/template/portal/*.*
nach: root/styles/art_helion/theme/portal.css
nach: root/styles/art_helion/theme/images/portal/*.*
Öffne: root/styles/art_helion/template/_menu.html
Öffne: root/styles/art_helion/template/overall_footer.html
Öffne: root/styles/art_helion/template/overall_header.html
Öffne: root/styles/art_helion/template/portal/modules/announcements_center_compact.html
{$CC_BLOCK_H_L}
{$CC_BLOCK_H_R}
{$CC_BLOCK_H_L}
	<dt>{$TITLE}</dt>
{$CC_BLOCK_H_R}
Öffne: root/styles/art_helion/template/portal/modules/news_compact_center.html
{$CC_BLOCK_H_L}
{$CC_BLOCK_H_R}
{$CC_BLOCK_H_L}
	<dt>{$TITLE}</dt>
{$CC_BLOCK_H_R}
Öffne: root/styles/art_helion/theme/stylesheet.css
Öffne: root/styles/art_helion/template/portal/_block_config.html
Reason: Anleitung ergänzt für rechte Sidebar in overall_footer.html und für Header in der overall_header.html
