IDLaunch Black
IDLaunch Black
This config works for both Styles / Diese Konfiguration funktioniert für Styles: IDLaunch Black v1.0.7
_block_config.html
<!--version $Id: _block_config.html v2.0.0b1 adapted by: Marc $ //-->
<!-- DEFINE $LR_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl class="icon"><dt style="padding: 0px 0px 2px; white-space: nowrap; margin-bottom: 0px; margin-top: 0px;">' -->
<!-- DEFINE $LR_BLOCK_H_R = '</dt></dl></li></ul><span class="corners-bottom"><span></span></span></div></div><div class="navbar"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li><dl><dd style="border-left: 0px; width: 100%;"><div style="text-align: left; margin: 5px 5px 5px 5px">' -->
<!-- DEFINE $C_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl class="icon"><dt>' -->
<!-- DEFINE $C_BLOCK_H_R = '</dt></dl></li></ul><span class="corners-bottom"><span></span></span></div></div><div class="navbar"><div class="inner"><span class="corners-top"><span></span></span>' -->
<!-- DEFINE $CC_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl class="icon">' -->
<!-- DEFINE $CC_BLOCK_H_R = '</dl></li></ul><span class="corners-bottom"><span></span></span></div></div><div class="navbar"><div class="inner"><span class="corners-top"><span></span></span>' -->
Note: This will probably also work for the other variations of IDLaunch.
none
Return to “v2.0.0b1 / v2.0.0 / v2.0.1 / v2.0.2”
