Portal 'button' not showing up under other theme
Jerree
Post by Jerree »
Hi, I just (tried) to install Portal 2.0, and 'Portal', (the button to go back to the portal) isnt showing up if I use a theme. If I set prosilver as theme, it does work.
With a theme (proFormell, but it's with other themes aswell)
prosilver:
Any ideas?
Thanks in advance,
Re: Portal 'button' not showing up under other theme
You need to apply the template and theme edits to your custom styles, too. Use the prosilver edits if they are based on prosilver and the subsilver2 edits if they are based on subsilver2.
Jerree
Post by Jerree »
I did (I think, :D). It still isnt showing up
awaismastimp1
phpBB.de User: awaismastimp1
phpBB.com User: awaismastimp1
Post by awaismastimp1 »
i am facing the same problem
in "prosilver" it is working but in "prosilver special edition" it is not working at all plz help me out also
Jerree
Post by Jerree »
Bump .
anywhere91
Translator
phpBB.com User: Anywhere91
Post by anywhere91 »
No changes made in the style displayed overall_header.html
Before
<li class="icon-home"><a href="{U_INDEX}" accesskey="h">{L_INDEX}</a> <!-- BEGIN navlinks --> <strong>&#8249;</strong> <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks --></li>
After
<li class="icon-home"><!-- IF U_PORTAL --><a href="{U_PORTAL}">{L_PORTAL}</a> &#187; <!-- ENDIF --><a href="{U_INDEX}" accesskey="h">{L_INDEX}</a> <!-- BEGIN navlinks --> <strong>&#8249;</strong> <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks --></li>
This works well if not;) example: http://area52.zone-bf.com/index.php?style=2
regards
Bonjour / Soir
Pas de changements faits dans overall_header.html du style affiché
Avant
Après
Cela fonctionne bien sinon ;) exemple : http://area52.zone-bf.com/index.php?style=2
cordialement
awaismastimp1
thanks my problem is solved
Return to “Styles Support”
