www.modifiedguild.com
As you can see each new thread posted under my "News" section is not separated with it's own "box."
How can I change/fix that?
Thread Post Separation Issue
- phpBB.de User: aznxhongkong
- phpBB.com User: aznxhongkong
Re: Thread Post Separation Issue
That's the way it usually looks.
In order to change that you would have to change a lot of code in the HTML file of the news block.
Ahh, okay thanks.
One other thing...
http://i.imgur.com/ZwPUc.png
In that how would I add a br spacing without having to put a custom top module? When you add a module it spaces it out from the top header.
One other thing...
This should fix that:
https://github.com/board3/Board3-Portal ... 49533546cb
Hmmm, I did the changes to the prosilver files, refreshed both the theme and template. Purged the cache and it seemed to not work.
Think of something I might of done wrong?
You need to edit your style's files.
The portal is installed under prosilver, but I'm using the swtor style also.
I thought all the code is usually shared between prosilver? Since I don't have portal files under my swtor style.
