Hi !
Thank for this great portal, it's more better than 1.0.6 version in ACP
I have installed on my forums (phpbb 3.0.9) whit succes but the update.xml are not working 'error xxx_portal_modules doesn't exist when i run 'install' folder. But I have uninstall the previous version for intalling 2.0.0b1 Portal and its work great
This is my problem Menu Button and stats link not showing on Portal , my file overall _header is the same in root/style/template/overall_header.html that root/portal/style/template/overall_header.html
My menu button showing on index.php but not on portal.php ????
Index.php
Portal.php
Do you have an idea of what file i have to edit y work on this since 2 days ... and i not find it
Sorry for my english i am french !
Thank's wido
Menu Button not showing on Portal
Re: Menu Button not showing on Portal
ok it's resolved it's my fault i have put the menu on in acp and it's showing .....
but i not undestand why because it's a manual install from phpbb-fr since one years and in the older version of the portal 1.0.6 the menu include it's not my menu ...
but all works great thank's for your hard work
