[fr-FRENCH] v2.0.0b1 News files
anywhere91
Translator
phpBB.com User: Anywhere91
Post by anywhere91 »
Key FR language only
Here are the new files in French.
Adding a file common.php changed and modified several key language portal on the blocks so you do not change their appearance (user menu, statistics, best posters, etc.)
See the result here => http://www.area52.zone-bf.com. As always thank you for me to return your comments and suggestions by MP
Regards
Clé de langue FR uniquement
Bonjour / Soir
Nouveaux fichiers de traduction.
Voici les nouveaux fichiers en version française.
Ajout d'un fichier common.php modifié et modification de plusieurs clés de langue sur les blocs portail afin de ne plus en modifier l'aspect (menu utilisateur, statistique, meilleurs posters, etc)
Voir le résultat ici => http://www.area52.zone-bf.com. Comme toujours merci de me faire le retour de vos remarques et suggestions par MP
Cordialement
root_fr.zip
(48.78 KiB) Downloaded 2498 times
wido
phpBB.com User: wido
Re: [fr-FRENCH] v2.0.0b1 News files
Post by wido »
Thank's
ttersu
phpBB.de User: ttersu
phpBB.com User: ttersu
Post by ttersu »
Thanks a lot!
Merci beaucoup! :D
EnYgmA
Post by EnYgmA »
Thx 8-)
MultiUser
phpBB.com User: MultiUser
Post by MultiUser »
Hi @ll , EnYgmA ;)
You Really A BOOS anywhere91 ! Thanks a lot !
I will test it and I come back with a screen or the result :D
Ever nice day .. or night^^ ...
. : Danke für Ihre Arbeit : .
papicx
phpBB.de User: papicx
phpBB.com User: papicx
Post by papicx »
Hello,
I'm French and excuse me, but my english is very bad.
just some mistake in file portal_calendar_module.php
line 39 to 42 :
	'EVENT_START'			=> 'du ',
	'EVENT_END'				=> 'au ',
	'EVENT_TIME'			=> 'Temps',
	'EVENT_ALL_DAY'			=> 'Aujourd’hui ? ',
line 116 and 117:
'ACP_PORTAL_CALENDAR_START_INCORRECT'	=> 'L\'heure de début que vous avez entrée est incorrecte. Suivre attentivement les instructions Merci.',
	'ACP_PORTAL_CALENDAR_END_INCORRECT'		=> 'L\'heure de fin est incorrecte. Suivre attentivement les instructions Merci.',
line 120 to 128 error, space in line end, date format incorect, and more indication :
'ACP_PORTAL_EVENT_START_DAY_EXP'		=> 'Entrez la date de début d\'événement. <br />La date doit être de ce format : JJ-MM-AAAA',
	'ACP_PORTAL_EVENT_START_TIME'			=> 'Heure de début de l\'événement. <br />(obligatoire si l’événement dure plus qu’une journée) ',
	'ACP_PORTAL_EVENT_START_TIME_EXP'		=> 'Entrez l\'heure de début de l\'évenement. <br />L\'heure doit être au format 24hrs, ex. 23:12',
	'ACP_PORTAL_EVENT_END_DAY'				=> 'Fin de l\'évènement ',
	'ACP_PORTAL_EVENT_END_DAY_EXP'			=> 'Entrez la date de fin de l\'événement. <br />La date doit être de ce format : JJ-MM-AAAA',
	'ACP_PORTAL_EVENT_END_TIME'				=> 'Heure de fin de l\'événement ',
	'ACP_PORTAL_EVENT_END_TIME_EXP'			=> 'Entrez l\'heure de fin de l\'évenement. <br />L\'heure doit être au format 24hrs, ex. 23:12',
	'ACP_PORTAL_CALENDAR_EVENT_START_FIRST'	=> 'La fin de l\'événement doit être après le début de l\'événement.',
	'ACP_PORTAL_CALENDAR_PERMISSION'		=> 'Permissions des événements ',
thank you.
anywhere91
Translator
The translation starts from the beginning
A new translation is being finalized for version 2.0.0 RC will be available very soon
Regards
Bonjour / Soir,
La traduction est remis à zéro.
La nouvelle traduction est en cours de finalisation pour la version 2.0.0 RC et sera disponible trés rapidement
Cordialement
Return to “v2.0.0b1”
