Marc wrote:obtain_portal_config() doesn't get called by index.php in Board3 Portal 2.0.0b1. If you updated from Board3 Portal 1.0.6, make sure that you removed old Board3 Portal MODs from your board.
Yes, I updated from 1.0.6.
In update.xml there was the list about files I should delete. I checked I have deleted all these files. Did you mean these files?
Delete: adm/style/acp_portal.html
Delete: language/en/mods/additional_blocks.php
Delete: language/en/mods/info_acp_additional_blocks.php
Delete: language/en/mods/install_portal.php
Delete: language/en/mods/lang_portal.php
Delete: language/en/mods/lang_portal_acp.php
Delete: portal/block/*.*
Delete: styles/prosilver/template/portal/portal_center.html
Delete: styles/prosilver/template/portal/portal_left.html
Delete: styles/prosilver/template/portal/portal_right.html
Delete: styles/prosilver/template/portal/block/*.*
Delete: styles/prosilver/theme/images/portal/mini_cal_icon_left_arrow.png
Delete: styles/prosilver/theme/images/portal/mini_cal_icon_right_arrow.png
Delete: styles/prosilver/theme/images/portal/portal_login.png
Delete: styles/prosilver/theme/images/portal/portal_minical.png
Delete: styles/prosilver/theme/images/portal/portal_random.png
Delete: styles/prosilver/theme/images/portal/portal_stats.png
Btw, on this forum, you should refresh imagesets or fix imagesets.cfg because I can see just about 3/4 of buttons.
