IE9 shows portal uncorrectly
Current Version: 2.0.2
Released: 2013-10-27
Anteli
phpBB.com User: Anteli
Post by Anteli »
As you see: the first center block is lower down than the first side block next to it. Same happens with all blocks when I'm using either PC version of IE9 or Windows Phone 7 version of IE9. Is there any way to fix this?
Thank you!
Anteli
Edit: Same happens also with other styles!
Pascal
Re: IE9 shows portal uncorrectly
Post by Pascal »
Have you made all changes in css stylesheet and upload this ?
which is based your style? Subsilver or prosilver?
Anteli
Post by Anteli »
Pascal wrote:Have you made all changes in css stylesheet and upload this ?
Thank you for your quick reply! I was suprised when I realized that I really hadn't made all changes in css stylesheet. Now I made those changes, uploaded the file and I refereshed themes. Unfortunately it didn't solve the problem. :(
I'm using we_clearblue style. I think it's not based on either of those styles.
Anteli
ixl
Sponsor
phpBB.de User: IXL
phpBB.com User: IXLUKCOM
Post by ixl »
I just wondered if you resolved your problem? ( Kirks post link no longer exists )
Im having the same problem with CA_Black theme taken from here : viewtopic.php?f=57&t=5399
Its fine in IE8, but dont know what I can do to make it work in IE9.
IXL
I.X.L
Just because it worked for you, doesnt mean it's right. ;)
http://WWW.TEAMGAMERS.CO.UK
