thankyou for such a great portal mod, works perfectly.
I dont know if I am posting this in the correct section, But is there a way to center the images that can be displayed as a welcome message?
I can put an image up using the img tags but cannot seem to center it. Please could you give me some advice on how it would be possible to do it.
Johnny
http://britishmetaldetecting.co.uk/
thanks
- phpBB.de User: Dalej
Re: thanks
I didn't want to start a new thread so I'll write in this one.
THANKS
I've been looking for something portal-like for ages, first writing it on my own in html & php, than trying with wordpress...
But nothing allowed me to integrate with forum so well like this thing, I hope it will grow big, and that I won't bother you too much with questions during my play-time with it.
THANKS
- phpBB.com User: noth
Re: thanks
what I like about this Portal is the huge STYLES TRACKER on this site. It just shows the enormous amount of support that is being provided. It is great to know that so much support is available to anybody embarking on Board3 and should they be using one of the major styles, that support is also there.
- Translator
Re: thanks
Thank you guys for all your work, I love Board and i use it on my forum, it's so usefull
I'd really like to help with translation, but I can't send private messages.
