[Release] Addon for phpBB Gallery 1.1.2+ for B3P v. 2.0.0
noth
- phpBB.com User: noth
Re: [Release] Addon for phpBB Gallery 1.1.2+ for B3P v. 2.0.
allowing the Gallery block a horizontal scroll bar looks good, I will try it
cheers
Crocodile
- phpBB.com User: Crocodile442
I am trying to reduce the size of the image shown in the side column. Can you point me to the right place?
Topic author - Portal Professional
You must make the settings in the gallery mod.Crocodile wrote:I am trying to reduce the size of the image shown in the side column. Can you point me to the right place?
You cannot separate setting for images in gallery lateral blocks.
Crocodile
Yes, that's what I thought. I changed the size in the Gallery Mod but it didn't change the size on the Portal. I cleared my cache and refreshed styles but it didn't make a difference.archivar wrote:]
Ah ha!!! I didn't think to clear the cache in the Gallery Mod. Sorry to have bothered you.
KakumeiTV
Kann mir vielleicht einer helfen die sachen hier mit der Galler für das Design zum laufen zu bekommen?
viewtopic.php?f=57&t=5323
- phpBB.de User: Kirk
Wenn du das Modul meinst,
Falls du die phpBB Gallery allgemein zum laufen bringen willst, dann frage beim Mod Autor oder bei phpbb.de nach.Lade das Modul Paket über den Admin-Bereich hoch oder lade den Inhalt der ZIP-Datei in das Hauptverzeichnis deines Forums
grazia
- Valued Contributor
i have this error, when install.php
help me please
phpbb_gallery_users' [1146] SQL SELECT * FROM WHERE phpbb_gallery_users user_id = 0 backtrace-
This does not work on the Portal Version 2.0.x
