Adventskalender Module for Board3 Portal 2.0.0b1
Vorraussetzung für das Modul ist das ihr den Mod Advent Calendar in eurem Board eingebaut habt.
Erstellt eine Datei namens portal_advent.php und fügt folgenden Code ein:
* @package - Board3portal Advent Calendar
* @copyright (c) 2009 Wuerzi http://www.spieleresidenz.de
* @ignore
if (!defined('IN_PHPBB'))
	exit;
* @package Advent Calendar
class portal_advent_module
	* top		1
	* left		2
	* center	4
	* right		8
	* bottom	16
	public $columns = 21;
	* Default modulename
	public $name = 'PORTAL_ADVENT';
	* Default module-image:
	public $image_src = '';
	* module-language file
	public $language = 'portal_advent';
	* custom acp template
	public $custom_acp_tpl = '';
	public $hide_name = false;
		global $config, $template, $user, $phpbb_root_path, $phpEx;
		// Numbersize
$class_size = array(
	'20',
	'30',
	'40'
// Font
$class_font = array(
	'font-family: Times New Roman, Georgia, Times;',
	'font-family: Arial, Helvetica, Geneva, Swiss, SunSans-Regular;'
// Fontcolor
$class_color = array(
	'white',
	'yellow',
	'silver',
	'red'
// Fontweight
$class_weight = array(
	'font-weight: bold;'
// Font
$class_style = array(
	'font-style: italic;',
	'font-style: normal;'
$ak_hover_size = 45;
$ak_hover_color = '#00FF00';
$tuer_tag_style = 'font-size: 50px; font-family: Arial, Helvetica, Geneva, Swiss, SunSans-Regular; color: white; font-weight: bold';
// Do noting change after this line!
$user->add_lang('mods/advent');
$tag_link = request_var('t', 0);
$a_path = (defined('ADVENT_PATH')) ? ADVENT_PATH : 'advent/';
$heute = mktime(date("H")+0, date("i"), date("s"), date("m"), date("d"));
$heute_m = date("m", $heute);
$heute_t = date("d", $heute);
$ak_verz = @opendir($a_path . 'images/back');
while($ak_bg_file = readdir($ak_verz))
	if($ak_bg_file != '.' && $ak_bg_file != '..')
		$ak_bg_files[] = $ak_bg_file;
$ka_bild = $a_path . 'images/back/' . $ak_bg_files[rand(0, count($ak_bg_files)-1)];
$tuer = array(1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24);
shuffle ($tuer);
$p_v = array('top', 'middle', 'bottom');
$p_h = array('left', 'center', 'right');
$kalender = '';
$pos=0;
for ($z = 1; $z <= 4; $z++)
	$kalender .= '<tr>';
	for ($s = 1; $s <= 6; $s++)
		if ($tuer[$pos] < $heute_t && $heute_m == 12)
			$tuerbild = $a_path . 'images/t_a_60.gif';
			$tuerbild = $a_path . 'images/t_60.gif';
		$class_color_rand = rand(0, count($class_color) - 1);
		$class_size_rand = rand(0, count($class_size) - 1);
		$kalender .= '<td align="' . $p_h[rand(0, 2)] . '" valign="' . $p_v[rand(0, 2)] . '">
			<table width="60" height="60" cellspacing="0" cellpadding="0" background="' . $tuerbild . '">
					<td align="center" valign="middle"><a href="' . append_sid("{$phpbb_root_path}advent.$phpEx", 't=' . $tuer[$pos]) . '" id="a' . $pos . '" style="font-size: ' . $class_size[$class_size_rand] . 'px; ' . $class_font[rand(0, count($class_font) - 1)] . 'color: ' . $class_color[$class_color_rand] . '; ' . $class_weight[rand(0, count($class_weight) - 1)] . $class_style[rand(0, count($class_style) - 1)] . 'text-decoration: none" onmouseover="ka_over(\'a' . $pos . '\');" onmouseout="ka_out(\'a' . $pos. '\', \'' . $class_color[$class_color_rand] . '\', \'' . $class_size[$class_size_rand] . '\');">' . $tuer[$pos] . '</a></td>
			</table></td>';
		$pos = $pos + 1;
	$kalender .= '</tr>';
$template->assign_block_vars('kalender', array(
	'KALENDER'    => $kalender,
	'IMG'         => $ka_bild,
$template->assign_vars(array(
	'S_ADVENT'			=> date("m") == 12 && date ("d") < 27,
	'AK_HOVER_SIZE'		=> $ak_hover_size,
	'AK_HOVER_COLOR'	=> $ak_hover_color
		return 'advent.html';
		return array(
			'title'	=> 'PORTAL_ADVENT',
			'vars'	=> array(),
	* API functions
		return true;
		return true;
Diese Datei kopiert ihr dann nach root/portal/modules
Als nächtes kommt die Sprachdatei, erstelle einen Ordner namens portal_advent.php und fügt folgenden Code ein:
* @author Adventskalender for phpbb3 © 2008 Wuerzi www.spieleresidenz.de
* @package phpbb3advent
* @version 0.1.0
* @copyright (c) 2008
* DO NOT CHANGE
	exit;
	$lang = array();
// DEVELOPERS PLEASE NOTE
	'PORTAL_ADVENT' 	        => 'Adventskalender',
Achtet darauf das ihr die Sprachdatei in der Kodierung utf8 ohne Bom speichert.
Diese Datei kopiert ihr dann nach root/language/de/mods/portal
Zum Schluß erstellt ihr noch eine Datei namens advent.html und fügt folgenden Code ein:
Für prosilver:
<!-- IF S_ADVENT -->
function ka_over(link)
	document.getElementById(link).style.color = "{AK_HOVER_COLOR}";
	document.getElementById(link).style.fontSize = {AK_HOVER_SIZE};
function ka_out(link, farbe, groesse)
	document.getElementById(link).style.color = farbe;
	document.getElementById(link).style.fontSize = groesse;
</script>
		<ul class="topiclist forums">
			<li>
				<dl>
					<dd style="width: 100%; text-align: center; border-left:0px;">
					<table width="100%">
						<!-- BEGIN kalender -->
			        		<td align="center">
								<table width="500" background="{kalender.IMG}" height="400">
									{kalender.KALENDER}
                        <!-- END kalender -->
					</dd>
				</dl>
			</li>
{$C_BLOCK_F_L}{$C_BLOCK_F_R}
Für subsilver2:
</script>
		<td class="row1" align="center"><br />
			<table width="500" border="0" cellspacing="0" cellpadding="5" background="{kalender.IMG}" height="400">
				{kalender.KALENDER}
			</table><br />
Diese Datei kopieren nach root/styles/dein stylename/template/portal/modules
Wechselt nun in´s ACP/Mods/PORTAL/Portal Module, klickt dort auf Modul Hinzufügen und wähl in der Liste
Adventskalender aus und klickt auf Absenden danach könnt ihr noch die Berechtigungen für dieses Modul einstellen.
Nicht vergessen den Cache zu leeren.
Anmerkung:
Dieses Portalmodul bekommst du nur angezeigt vom 1.12 - 26.12
Wenn du es dennoch angezeigt haben willst, dann lösche in der advent.html in der ersten Zeile das hier:
und in der letzten Zeile das hier:
Pascal
Re: Adventskalender Module for Board3 Portal 2.0.0b1
Post by Pascal »
Hi Erstmal Gute Arbeit aber ich habe mich an deine Anleitung gehalten und bekomme mit diesem Modul immer Kompressionsfehler in Firefox woran liegt das ?
@Mods
wenn ich hier falsch poste bitte in das richtige Thema schieben
Schau im ACP/Server und Domain ob bei gzip-Komprimierung aktivieren auf ja gesetzt ist setz es mal auf nein.
Pascal
Post by Pascal »
Werde ich beizeiten mal probieren, aber das ist doch eigentlich gut gzip oder ?
Hab damit noch keine Erfahrung gemacht,aber hast du dir mal die Beschreibung unten gelesen?
Erfordert, dass die zlib-Erweiterung von PHP geladen ist.
DocSommer
Post by DocSommer »
Drollige Idee - leider werde ich dieses Jahr wohl nicht mehr auf das 2.x Portal umsteigen. Als neuer "Kalenderexperte" muss ich glatt mal nachhaken, ob du vielleicht auch einen Kalenderblock für den "calendar mod by alightner" umsetzen könntest?
Jan
Da muß ich passen, hab keinerlei Erfahrung mit diesem Kalender Mod.
Aber für dich als neuer "Kalenderexperte" dürfte das bestimmt kein Problem sein. ;)
DocSommer
Post by DocSommer »
Ich wollte zwischenzeitlich auf phpBB.com im Dev Thread des Kalenders nachhaken und musste feststellen, dass der Kalender -trotz einer großen Popularität - seitens des Modentwicklers wohl nicht weiter betreut wird und daher als "abandoned" geflaggt wurde, von daher wird man sich hier wohl mittelfristig eine Alternative suchen müssen.
redbull360
phpBB.de User: redbull
phpBB.com User: redbull
Post by redbull360 »
English version please
Englisch Instructions
Requirement for the module is it the mod Advent Calendar have built into your board.
Creates a file named portal_advent.php and add the following code:
* @ignore
	exit;
	* top		1
	* left		2
	* center	4
	* right		8
	* bottom	16
		// Numbersize
	'20',
	'30',
	'40'
// Font
// Fontcolor
	'white',
	'yellow',
	'silver',
	'red'
// Fontweight
// Font
shuffle ($tuer);
$kalender = '';
$pos=0;
			</table></td>';
		$pos = $pos + 1;
	'IMG'         => $ka_bild,
		return array(
			'vars'	=> array(),
	* API functions
		return true;
		return true;
Copy that file to root/portal/modules
Next comes the voice file, create a folder called portal_advent.php and add the following code:
* @version 0.1.0
* DO NOT CHANGE
	exit;
	$lang = array();
	'PORTAL_ADVENT' 	        => 'Advent Calendar',
Makes sure that her voice file in the code utf8 without Bom stores.
This file then copy it to root/language/en/mods/portal
Finally, it creates another file named advent.html and add the following code:
For prosilver:
</script>
			<li>
				<dl>
			        		<td align="center">
									{kalender.KALENDER}
					</dd>
				</dl>
			</li>
For subsilver2:
</script>
				{kalender.KALENDER}
			</table><br />
Copy that file to root/styles/your style name/template/portal/modules
Will now go into the ACP / mods / PORTAL / portal modules, click here to add modules and selectable in the list
Advent calendar from clicking the submit button and then you can still set the permissions for this module.
Do not forget to flush the cache.
Note:
This portal module you just get displayed from 1.12 - 26.12
If you want it to still be present, then delete the advent.html in the first line here:
and in the last line here:
Sorry for my bad english I am German
cctreff
phpBB.de User: Pfiffy
phpBB.com User: Pfiffy
Post by cctreff »
Servus Kirk,
ich hab heute versucht, das Portalmodul nach deiner Anleitung zu erstellen. Leider hab ich danach folgendes Problem: Ich klicke im ACP auf "Portal Module" und bekomme nur noch die Meldungen
[phpBB Debug] PHP Warning: in file [ROOT]/adm/index.php on line 161: Cannot modify header information - headers already sent by (output started at [ROOT]/portal/modules/portal_advent.php:1)
[phpBB Debug] PHP Warning: in file [ROOT]/adm/index.php on line 163: Cannot modify header information - headers already sent by (output started at [ROOT]/portal/modules/portal_advent.php:1)
[phpBB Debug] PHP Warning: in file [ROOT]/adm/index.php on line 164: Cannot modify header information - headers already sent by (output started at [ROOT]/portal/modules/portal_advent.php:1)
[phpBB Debug] PHP Warning: in file [ROOT]/adm/index.php on line 165: Cannot modify header information - headers already sent by (output started at [ROOT]/portal/modules/portal_advent.php:1)
Rufe ich danach das Portal auf steht ganz oben (oberhalb des eigentlichen Portals):
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4919: Cannot modify header information - headers already sent by (output started at [ROOT]/portal/modules/portal_advent.php:1)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4921: Cannot modify header information - headers already sent by (output started at [ROOT]/portal/modules/portal_advent.php:1)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4922: Cannot modify header information - headers already sent by (output started at [ROOT]/portal/modules/portal_advent.php:1)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4923: Cannot modify header information - headers already sent by (output started at [ROOT]/portal/modules/portal_advent.php:1)
Hast du eine Idee, wo ich suchen könnte?
Grücce
Pfiffy
Diesen Mod hast du aber schon eingebaut?
Ohne funktioniert es nicht.
Edit:
Wie ich gesehen habe hast du den AroBlue Style in dein Board, hab ihn mal Testweise eingebaut.
Kann keinen Fehler erkennen hier auf mein Testboard kannst du es selbst sehen.
Hast du vielleicht in der [ROOT]/portal/modules/portal_advent.php eine ungewollte Leerzeile hinter ?>
Hier steht noch meht über solche Fehlmermeldung: https://www.phpbb.de/kb/headers_already_sent
Ich kann es leider nicht nachvollziehen.
Lad dir das ganze Modul hier runter und spiel es erneut auf.
cctreff
Post by cctreff »
Servus Kirk,
Danke für die Hilfe. Klar hab ich die MOD drin. Und ja, ich hab ein (bzw. mehrere) Aero-Style. Allerdings alle nicht mehr im Grundzustand sondern stark abgepasst und die Installation hab ich eh in meinem Testsystem gemacht, nicht im Echtsystem (im Testsystem gibt es auch Standard-prosilver).
Ich hab mal das ZIP-File runter geladen und das verwendet. Nach dem Hochladen über die Portalfunktion hat es mir zwar einige Verzeichnisrechte zerschossen (das war schnell behoben), aber jetzt funktioniert das Portalmodul! Ich habe dann die selbst erstellten Files und die aus deinem ZIP-File mit Notepad++ verglichen. Aber mit Ausnahme der Copyright-Hinweise gibt es keinen Unterschied. Ist mir ein Rätsel das Ganze. Bin gespannt, wie es sich in meinem Echtsystem verhält..... Aber das kenn ich ja als Systemadmin: EDV=Ende der Vernunft.... :D
Danke für deine Hilfe und ein schöne Zeit!
Grücce
Pfiffy
Am besten du vergleichst mal die Dateien mit WinMerge
da sieht man die Unterschiede besser.
Schönen Tag noch! :)
Edit:
Was mir gerad aufgefallen ist, wenn man einen Code mit dem FF Browser kopiert bekommt man vor <?
ein Leerzeichen, was dann diese Fehlermeldung verursacht.
cctreff
Post by cctreff »
Danke Kirk. Notepad++ hat auch eine Erweiterung namens "Compare", da sieht man auch alle Unterschiede recht schön farbig aufbereitet. Und so wie es aussieht war es die Leerzeile, die der liebe Firefox einfügt.....
Grücce
Pfiffy
Return to “Modifications - In Development v2.0.x”
