Requesting config for Aero portal v2.0.0b1
PCGUY112887
phpBB.com User: PCGUY112887
Post by PCGUY112887 »
Hello,
Let me start off by saying that I LOVE this portal!
I had my block_config.html file setup for version 1.6 of the portal, but I can't seem to get it setup for v2. I tried using the block_config from 1.6, and the left bar looks OK but I can't make the center bars look correct!
I am using the Aero theme.
http://www.phpbb.com/community/viewtopi ... 4&t=639995
Can anyone help? I'm going to provide the block_config I have been using for 1.6
Thanks!
    <!-- DEFINE $LR_BLOCK_H_L = '<table width="200px" border="0" cellpadding="0" cellspacing="0"><tr><td class="tl"></td><td class="tm"></td><td class="tr"></td></tr><tr><td class="ml"></td><td><div class="cat"><ul class="topiclist"><li class="header"><dl class="icon"><dt style="padding: 3px 0px 2px; white-space: nowrap;">' -->
    <!-- DEFINE $LR_BLOCK_H_R = '</dt></dl></li></ul></div><ul class="topiclist forums"><li><dl><dd style="border-left: 0px; width: 100%;"><div style="text-align: left; margin: 0px 0px 0px 5px;">' -->
    <!-- DEFINE $LR_BLOCK_F_R = '</td><td class="mr"></td></tr><tr><td class="bl"></td><td class="bm"></td><td class="br"></td></tr></table>' -->
    <!-- DEFINE $C_BLOCK_H_L = '<table width="100%" border="0" cellpadding="0" cellspacing="0"><tr><td class="tl"></td><td class="tm"></td><td class="tr"></td></tr><tr><td class="ml"></td><td><div class="cat"><ul class="topiclist"><li class="header"><dl class="icon">' -->
    <!-- DEFINE $C_BLOCK_H_R = '</dl></li></ul></div>' -->
    <!-- DEFINE $C_BLOCK_F_R = '</td><td class="mr"></td></tr><tr><td class="bl"></td><td class="bm"></td><td class="br"></td></tr></table>' -->
    <!-- DEFINE $BLOCK_DISTANCE = '0px' -->
Re: Requesting config for Aero portal v2.0.0b1
If the beta status of B3Pv. 2 is completed, the style adjustments will be published.
Please have patience.
Return to “Config requests”
