Recent topics / mechanisms
Current Version: 2.0.2
Released: 2013-10-27
MagnusB
Post by MagnusB »
I like the new release so far, but I have a few questions, as I can't really figure it out.
Recent topics block is something that I really need for my site, and right now I am trying to get it to behave as I want it to / have in 1.x. But right now, only recent topics appear, I also need popular topics to appear, but I have no idea how to get them to appear. I am testing it now on a fresh phpbb3 install, with only a few topics being made for testing, and I keep replying to one, but no such luck.
I also tried to boost the view counts, but still no luck.
Additionally, I need to change the headers for each column, while this was easy in previous release, it seems to have changed a bit. Is there a way to change them in the language file, instead of changing the HTML after each upgrade? E.g. recent topics become recent news, popular topics become popular news, or similar. I only want to change them in that block though. Other blocks will be used differently.
MagnusB
Re: Recent topics / mechanisms
Post by MagnusB »
I figured the last part out, and managed to change the language files as I wanted.
However, my initial problems still exists. I am using a demo forum, with 2 users. I am trying to spam post a bit, but no luck getting any posts into Popular / Hot topics in the recent block. Any help on this / tips on how it works?
MagnusB
Post by MagnusB »
Is there any update on this?
I can not get any topics to appear in the Popular topics table, though the config for this block lets me set how many I want included. Is this just a placeholder for future release, or does the block support this right now?
phpBB decides if a topic is "hot"/popular. There is not much we can about this without a lot of database queries.
If you do not have popular topics the portal can't display any.
playagiron
Post by playagiron »
But you can change the threshold for Hot Topics:
ACP => Posting => Post Settings => Popular topic threshold:
Standard is 25, but if you set it to a lower number, you will have some hot topics and they should show up!
clight77
phpBB.com User: clight77
Post by clight77 »
Thanks,I was looking how to fix this also :)
