I installed the Portal 2.0.0b1 and everything works fine, except when you login that it is impossible to see the portal and always redirects to the index.
Thanks in advance.
Login users cant to go portal
kolmao
- phpBB.com User: kolmao
Re: Login users cant to go portal
Make sure that your users are allowed to see the portal.
kolmao
Ahhh, thanks, were permission issues ... solved
Hi-vani2
- phpBB.de User: Hi-vani2
- phpBB.com User: Hi-vani2
Hello from Greece.
I also want your help on a similar problem.
The first time I visit my site I can see the portal board3 - last version and phpbb 3.0.0 ... is wonderful.
But after I seeing only the forum and not the portal !
Can you help me please?
What does last version of Board3 Portal mean and why are you still using phpBB 3.0.0? Board3 Portal was written for phpBB 3.0.8.
