I have tried this and still have the same problem, I always get the same message that it is corruptedMyLady wrote:have a look to the chmod of module files on your server - may be, they are read protected. Set them to 644 if it is so.
[Release] mChat Block for Board3 Portal 2.0.0
Armgaming
Re: [Release] mChat Block for Board3 Portal 2.0.0b1
oppahansi
Chatbox installed, it is also showing up as a module on the portal. The only thing is, that it cannot pass the loading. I also cant post anything. Weird.
Any ideas why this is happening?
http://www.dayzbrahs.de - permissions for guest: can see the mchat and view archive.
EDIT:
It is only bugged with the style i chose: CODFaction.. dont know why, if i change back to prosilver it is working well. -.-
EDIT:
CHUCKY
hmm ich habe alle nötigen rechte vergeben aber trotzdem habe ich nur einen blauen balken wo
drinn steht!!habe nach dem entpacken die datein aus dem root ordner so wie beschrieben auf dem webspace geladen!weiss vieleicht jemand rat ?
danke im vorraus!oder weiss jemand ein anders chat bzw shoutbox mod für das portal ?
{ MCHAT_TITLE }
{ MCHAT_ENABLE }
{ MCHAT_COPYRIGHT }
- phpBB.de User: Kirk
@CHUCKY:
Dir fehlen die deutschen Sprachdateien für den mChat Mod.
The style CODFaction is based on subsilver2, Note the instructions for subsilver2oppahansi wrote:Chatbox installed, it is also showing up as a module on the portal. The only thing is, that it cannot pass the loading. I also cant post anything. Weird.
EDIT:
CHUCKY
hmm ich hab immer noch das problem!kann ich nich einfach die sprachdatei vom englischen in den deutschen ordner kopieren ?ioh man jetzt hab ich es nochmal installt und bekomme einen neuen fehler -.-
hmm ich such mal weiter
Allgemeiner Fehler
SQL ERROR [ mysqli ]
Table '****.MCHAT_CONFIG_TABLE' doesn't exist [1146]
SQL
SELECT * FROM MCHAT_CONFIG_TABLE
BACKTRACE
FILE: (not given by php)
LINE: (not given by php)
CALL: msg_handler()
FILE: [ROOT]/includes/db/dbal.php
LINE: 757
CALL: trigger_error()
FILE: [ROOT]/includes/db/mysqli.php
LINE: 182
CALL: dbal->sql_error()
FILE: [ROOT]/includes/functions_mchat.php
LINE: 31
FILE: [ROOT]/mchat.php
LINE: 64
CALL: mchat_cache()
FILE: [ROOT]/portal/modules/portal_mchat.php
LINE: 72
CALL: include('[ROOT]/mchat.php')
FILE: [ROOT]/portal.php
LINE: 103
CALL: portal_mchat_module->get_template_center()-
Da dieses nichts mit dem mChat Block zu tun hat, wende dich bitte damit an den Modentwickler oder an www.phpBB.de
CHUCKY
hmm oki doki!ich werd heute abend nach der schicht mal nach dem fehler suchen! danke dir trotzdem für deine hilfe!
Hab den fehler gefunden :d! war mein fehler! hab ein fehler beim editieren in der constants.php gemacht!
kabuto93
Macht dieses mit der neuer mChat Übertragung? Entschuldigung, mein Deutsch ist nicht so gut.
Does this work with the new mChat release?
With this block it works. http://www.quad-atv-freunde-wunsiedel.d ... 128&t=1597kabuto93 wrote:Does this work with the new mChat release?
kabuto93
HoodieWeather
- Valued Contributor
I just installed the mchat from here https://www.phpbb.com/customise/db/mod/ ... w_version/
I'm running 3.0.13
Now, if I wanted a chat on the board3 portal, I'd have to write module? If, so.... has anyone done this yet, that would mind sharing the file?
Thanks
I'm running 3.0.13
Thanks
HoodieWeather
Kirk wrote:HiWith this block it works. http://www.quad-atv-freunde-wunsiedel.d ... 128&t=1597kabuto93 wrote:Does this work with the new mChat release?
Just downloaded the block saved the .zip to desktop uploaded the .zip under Portal / Upload Module.. I got two errors with the themes
./../language/de/mods/portal/portal_mchat_module.php
./../styles/subsilver2/template/portal/modules/mchat_center.html
The rest were a Success
how can i fix those two errors?
grazia
this no work to phpmm 3.1 and portal 2.10Marc wrote:Addon: mChat Block
Addon Version: 1.1.0
Addon Author: Marc Alexander
Addon Description:
Adds an mChat window to your portal page.
Addon Requirements: Board3 Portal 2.0.0 and newer and mChat 1.3.5 by RMcGirr83
Download:
Instructions:
Upload the module package via the ACP or just upload the content of the ZIP-File into the root of your forum.
Lade das Modul Paket über den Admin-Bereich hoch oder lade den Inhalt der ZIP-Datei in das Hauptverzeichnis deines Forums.
Updates:
19th May 2011: Added missing <br /> in prosilver
