portal on all style type's
tdk
Post by tdk »
Your Portal Version: 1.0.6
Hello,
is it possible yet to install the board3 portal on all style type's,if yes how do i do it.
On some of the prosilver type's it wont work(also on some subsilver type's.)
how can i resolved the problem so i can use the portal on all styles.
Thx for all the answers.
TDK
Re: portal on all style type's
Return to “Styles Support”
