Change color on portal
wanted
phpBB.de User: wanted
Post by wanted »
Boardlink: http://web218.webgo24-server8.de/work/d ... portal.php
Nothing! Problem was there since the beginning
I tried a few things but nothing worked! I do not find the exact file!
Hello,
I need two things done on my portal site! Hope you guys know where I have to watch and where I can find it.
1) On the right side at the mini calendar you can see that the sundays are in red! I want them to be in the same orange as I have it everywhere else! Where do I have to change it and does somebody know the hex-code for my orange color I am using?
2) On the top of the portal there is a text with "Aktuelle Zeit: Tag, Monat, Uhrzeit" which is translated to "Actual Time: Day, Month, Time"! I need this in bold and the characters should have the hex-code "#f1f1f1"
Where can I change this?
Hope somebody can help me out!
Thanks,
Chris
Re: Change color on portal
Warum in englischer Sprache? :roll:
wanted wrote: Boardlink: http://web218.webgo24-server8.de/work/d ... portal.php
zu 1.)Das kannst Du hier einstellen: acp_demo/de/kalender.php.html
wanted wrote: 2) On the top of the portal there is a text with "Aktuelle Zeit: Tag, Monat, Uhrzeit" which is translated to "Actual Time: Day, Month, Time"! I need this in bold and the characters should have the hex-code "#f1f1f1"
zu 2.)Das hat mit dem Portal nichts zu tun!!!!!!!!!!!
Die Schriftfarbe wird automatisch vom Style übernommen.
Wende dich damit bitte an phpbb.de oder an den Style-Autor.
Return to “Styles Support”
