Install Error
bvr
Install Error
Post by bvr »
Boardlink: http://realmgx.net
Freshly installed phpBB3, and a subsilver based template.
Reupload everything overwriting.
I get this error
Prior to running the installation script, you need to upload the edited files, especially /includes/constants.php.
Those files are uploaded I triple checked I dunno what its problem is. I installed this portal on my other forums a few months ago with no problems.[/i]
bvr
Re: Install Error
Post by bvr »
Oh and I get that error when I try to install via url.
Re: Install Error
Did you edit the files as instructed in install.xml?
bvr
Re: Install Error
Post by bvr »
yeah, I did.
Re: Install Error
Well it seems like you didn't edit your constants.php correctly.
bvr
Re: Install Error
Post by bvr »
wow it worked, must have overlooked it. Now I have this error after install.
Parse error: syntax error, unexpected $end in /home/realmgx/public_html/cache/tpl_ColdSteel_overall_header.html.php on line 211
