610nm
Evanonian
phpBB.de User: Evanonian
phpBB.com User: Evanonian
610nm
Post by Evanonian »
Is there a way you can make this pass the W3C CSS Validation? XHTML Checks out but not the CSS I would do it if I had the knowledge. I really like this theme and appreciate you making it compatible with this Portal.
http://jigsaw.w3.org/css-validator/vali ... =1&lang=en
www.ctrl-alt-defeat.com
In advanced, thanks keep up the good work.
P.S. It's not important I just like to be valid. =P
Re: 610nm
Evanonian
Re: 610nm
Post by Evanonian »
Thanks! that fixed it :D
Return to “Styles Support”
