Problem with Welcome block
blackhex666
phpBB.de User: blackhex666
phpBB.com User: blackhex666
Post by blackhex666 »
Boardlink: http://95.76.144.21
I instaled some mods,i maded some modifications to Prosilver Style
i had some problems with the Subject Prefix Mod i unistaled i instaled so on
i Resored from an old backup
so i dont know when the welcome block disapeard ....but is gone
Nothing:| i don`t know what to ....
I really need some help...did some one else had this problem?
i searched the forum but nothing....
the welcome block is set to Yes
Re: Problem with Welcome block
You probably set the Welcome Block to only be seen by Guests. If that is set to yes, you won't see the Welcome Block, but I can see it.
And yes, I can see it. If you also want to see the welcome block, then just set this option to no in the ACP. ;)
