ok so me and teksonic have been working on a NEW world of warcraft recruitment block for board3. public Alpha is ready for testing.
DEMO: http://www.teksonicmods.com/ on the right hand side.
Support and Requests: http://www.teksonicmods.com/viewtopic.php?f=16&t=35
this new recruitment block includes;
class AND spec icons with a mouseover tooltip to display the current state of recruitment and also the spec icons have transparency set to them depending on the state of recruitment.. faded for not required. bold for required.
the whole block comes with an easy to install ACP aswell so you have easy management over the display of required recruitment needs
take a look @ it and tell us what you think.
Warcraft Recruitment block
Topic author - Portal Specialist
- phpBB.com User: talonos
Re: [Alpha] Warcraft Recruitment block
This was by far, the easiest install of any mod I've seen out there. Its very efficient and easy to use once installed. My officers love it and appreciate a recruitment block that FINALLY makes sense. Job well done!
cant get registed on your site please check admin email or pm me a dl link plz
Updated to 2.1.0. please visit forums above for more info.
the update includes the new Pandaria MONK class.
we're still working on board3 v2 capabilities atm.
