Need Some Help Plz
icyshadowz
Need Some Help Plz
Post by icyshadowz »
[phpBB Debug] PHP Notice: in file /portal/block/statistics.php on line 91: Division by zero
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3395: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2922)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3397: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2922)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3398: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2922)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3399: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2922)
I dont know what i did wrong but this is what i get also http://www.geckosunited.com is still normal when it should be http://www.geckosunited.com/portal.php any suggestions
Re: Need Some Help Plz
Create a post and the error is gone.
icyshadowz wrote:I dont know what i did wrong but this is what i get also http://www.geckosunited.com is still normal when it should be http://www.geckosunited.com/portal.php any suggestions
Edit the .htaccess as described in the install.xml
icyshadowz
Kevin wrote:Create a post and the error is gone.
thanks all fixed
see i did that is there more then one that im not seeing there isnt one in the root is there suppose to be
icyshadowz
if i just change portal.php to index.php will that be fine and work the same
icyshadowz wrote:if i just change portal.php to index.php will that be fine and work the same
No.
icyshadowz wrote:see i did that is there more then one that im not seeing there isnt one in the root is there suppose to be
Configure your FTP client so show hidden files. ;)
icyshadowz
ok i fixed it created my own and now it works thanks again for the fast responses
You're welcome. Have fun with the portal! :)
odklizec
phpBB.com User: odklizec
Post by odklizec »
Hello,
Sorry for reopening this old discussion. I have very similar (the same) problem. I recently moved the forum to a new host. Everything went fine but Portal now says:
[phpBB Debug] PHP Notice: in file /includes/functions_content.php on line 967: Division by zero
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3805: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3184)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3807: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3184)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3808: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3184)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3809: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3184)
I checked the htaccess file and yes, it's modified as described in the installation guide. I tried to refresh the styles as well as to purge the forum cache but still no luck. Any idea what to do now? Thank you in advance!
Ricoh Digital and Film Cameras
http://www.ricohforum.com/
Please upload a copy of your includes/functions_content.php
odklizec
Post by odklizec »
Hi Marc,
Thanks for reply! Please accept my apology. It was a false alarm. I found the reason of this issue. It was caused by an image with corrupted EXIF and the error was produced by NVEXIF mod. The funny thing is, that this kind of problem usually happens only if someone visits the post with corrupted image. But in this particular case, it was enough that the post with problematic attachment was listed in the "Latest News" block. I fixed the EXIF and all is OK now. Once again sorry! ;)
