[Solved] Portal Images not showing
- phpBB.com User: SheepyDaz
Your Portal Version: 1.0.6
MODs installed: Moved Portal.php outside of forums directory - knowledge/kb_show.php?id=2
Boardlink: http://concept.ulmb.com/index.php
Installed the new skins X-Treme
Tried to edit the _block_config.html with the one here - viewtopic.php?f=44&t=3950
Hey there.
Ive recently installed the X-Treme skin onto my board.
I followed all the steps in the install.
After editing the _block_config.html none of the images show up around the portal blocks.
The images are in the correct path.
I have purged cache, refreshed the style an imageset's more than enough.
And the images are still not showing.
Any help is much appreciated.
Thanks in advanced
Hey there.
Thanks in advanced
"Two things are infinite: the universe and human stupidity; and I'm not sure about the universe."
Re: Portal Images not showing
Hi,Sheepy wrote: Boardlink: http://concept.ulmb.com/index.php
You made some mistakes in the overall_header.html.
Please check.
viewtopic.php?f=47&t=3813
EDIT:
Or try using the new here:
Open: styles / X-Treme / template / overall_header.html
Find:
<div id="wrapcentre">
you say
Also with them extra bits of code you added do I replace the orginal code from here viewtopic.php?f=47&t=3813 an just add them edit?
Sorry but im confused now
Before or after?Then add:
Add after:!Sheepy wrote:you sayBefore or after?Then add:
Sorry for my bad English.
Nahh its not a problem Thanks for at least helping mearchivar wrote:Add after:!Sheepy wrote:you sayBefore or after?Then add:
Ive made the required edits you suggested but still no luck. This is really weird because if i open the site in IE8 i can right click the images an it shows the correct file paths, just no images :S
Refresh your Styles:
Ive done this numerous times mate, still no luck.archivar wrote:Refresh your Styles:
I even ran ccleaner an used google chromes own built in clean cache tools :S
Copy the cache folder on your server.
Clean up your server's cache.
Not clear the files .htaccess and index.htm in the folder cache!!!!!!!!
Also with me is on the style it difficult to clean the cache.
OK, i Manually cleared the cache, still no goodarchivar wrote:Copy the cache folder on your server.
Ill see if it works on my laptop
The portal.php is not found.
Check the .htaccess in the folder where the portal.php stands.
and includes/functions.php
Show----> install.xml
????????-->http://concept.ulmb.com/forums/portal.php
????????-->http://concept.ulmb.com/portal.php
the portal.php has been moved to a differant location.
My forums is laid out like this -
root - index.php (portal.php)
forums
index.php is really portal.php.
Hence why when you visit http://concept.ulmb.com you see the portal.
forums
That is not in the install.xml of Board3Portal!Sheepy wrote:the portal.php has been moved to a differant location.
If you've done something else then you would have given the information at the very beginning have to, because we are not clairvoyant.
Then we would not write so much.
Look here--->Moving portal.php outside of your forums directory
sorry it slipped my mind as I did a fresh install this afternoon, an restored my tables.
There is nothing in that article which corresponds to those images not showing up on the portal.
So it has to be something with the theme/style files.
search in _block_config.html:
find everything:
hereby replaced:
find everything:
./styles/
./forums/styles/
That workedarchivar wrote:search in _block_config.html:
find everything:hereby replaced:Code: Select all
./styles/
./forums/styles/
Thank you
How stupid do i feel Sorry for not supplying the info about the portal.php being moved.
