Portal Issue
sordid
Portal Issue
Post by sordid »
Your Portal Version: 1.0.6
Boardlink: http://mdma.lawltotems.net/test
PHP Version: 5.0
Installed Recruitment Block and Raid Progress Block
Went through the code little by little, had my hosting provider admins look through it trying to fix it...couldnt figure it out. The Portal is using a theme called pbwow_cataclysm.
a good example of how its supposed to look can be found here http://devierum.org or http://pbwow.com/forum/viewforum.php?f=3
I went all over this forum, i had my hosting provider admins look over it, i have went through the code little by little, i went through my error logs in my cpanel, i cannot figure out why the theme is not loading right, i have it in a test folder right now, located at http://mdma.lawltotems.net/test/. If someone can take a look and shed some light on whats happening, i would be most appreciative.
mdma - a game progression guild (world of warcraft)
Sordid
Re: Portal Issue
sordid wrote: Boardlink: http://mdma.lawltotems.net/test
You have a different _block_config.html (prosilver) in the folder styles / PBWoW / template / portal /.
Build your old _block_config.html again.
Or take the _block_config.html from the original style.
Refresh your Styles:
And clean the browser cache.
The pictures in the center block are much too large.
So that your side is pressed in the width.
Return to “Styles Support”
