Portal as Main Page
bvr
Portal as Main Page
Post by bvr »
Boardlink: http://www.battlecows.com
I installed phpbb3 on my root folder, battlecows.com leads to my phpbb3. I installed the portal. But when I type my webpage it goes to index.php instead of portal.php? How do I fix this? Also, on the donation blocks, how do I set it to US currency instead of Euros for the default?
Re: Portal as Main Page
It seems like you are missing some edits. Make sure you edit .htaccess as instructed by install.xml.
Also it seems like you forgot to edit your style. As it seems to be based on subsilver2 you should follow the subsilver2 instructions.
bvr
Post by bvr »
This should be right.
#<IfModule mod_rewrite.c>
#RewriteEngine on
#</IfModule>
<Files "config.php">
Order Allow,Deny
Deny from All
</Files>
<Files "common.php">
Order Allow,Deny
Deny from All
</Files>
If it doesn't work that way, contact your hoster and ask if they can help you with setting the homepage to portal.php.
bvr
Post by bvr »
is there any other way? My host is slow at getting back with me. When I ran a vbulletin board, I did something like rename the index.php to old_index.html or something. Its been been a long time. I could just rename portal.php to index.php but then I would have to change links to all the forum index files.
Renaming the index file would result in a 404 error, so I wouldn't do that.
Romano
Post by Romano »
How did you resolve this bvr? i will like to make the portal my homepgae also.
Wateva
Post by Wateva »
Create an index.htm/html/php with an instant redirect to portal.php
Romano
Post by Romano »
Thnak you, but i have already an index.php, to the forum, how do i do that?
As I already said, if editing the .htaccess file does not work do the following:
