greeb
greeb
This config works for both Styles / Diese Konfiguration funktioniert für Styles: greeb
First you need to download and install this Style.
to: styles/greeb/template/portal/*.*
to: styles/greeb/theme/portal.css
to: styles/greeb/theme/images/portal/*.*
Als erstes musst du das Style downloaden und Installieren.
nach: styles/greeb/template/portal/*.*
nach: styles/greeb/theme/portal.css
nach: styles/greeb/theme/images/portal/*.*
open: styles/greeb/template/portal/_block_config.html
replace with:
Öffne: styles/greeb/template/portal/_block_config.html
Ersetze mit:
<!--version $Id: _block_config.html v1.0.4 adapted by: Mike $ //-->
<!-- DEFINE $LR_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl><dt style="padding: 0px 0px 2px; white-space: nowrap; margin-bottom: 0px; margin-top: 0px;">' -->
<!-- DEFINE $C_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl class="icon">' -->
<!-- DEFINE $C_BLOCK_H_R = '</dl></li></ul>' -->
no
