Boardlink: http://smalliance.com/test/
Installed fresh phpbb3 then modded for EVE member registration (dont think this is a problem could be wrong)
Tried checking all modded files everything looks good. MOD works great until I try to login then I get Server 500 error. Resaved all edited files using Notepad++ didnt seem to change anything double checked .htaccess didnt seem to help.
Installed with no errors board works fine until you try to login then after login you get server 500 error. You can still browse the forums if you use http://www.site.com/forums/index.php but whenever you try to load portan (portal.php) you get server 500 error I can still access forum ACP with no issues when logged in mod is enabled not sure whats wrong. Any help would be much appriciated.
Server Error 500 after login
Re: Server Error 500 after login
Try if turning on debug mode in your config.php displays you any error messages. Also it would help to know what PHP version you use.
php version 5.2.12, turned debug on but no result just server error 500 (doesnt display any additional information).
Not sure whats up.
Not sure whats up.
Figured it out on my own guys just had to update phpbb as I seem to have downloaded 3.05 on my first go everything thing looks to be fine after the upgrade to 3.07
Thanks.
Thanks.
