Variable News Blurb Using BBCodes
Epochalepse
Post by Epochalepse »
I'm looking at Board3/phpbb3 as a possible replacement at my site. Consequently, I'm also looking at the portal for ease of modification.
One immediate shortcoming I found was that including pics or vids which have long URLs in the news summary/teaser/blurb is problematic when the embedding code exceeds the Board 3 news teaser character limit.
A simple solution is presented here which does not impact the character limit method.
STEP 1:
In the ACP, create a dummy BBCode with no replacement parameters in the form:
[blurb][/blurb]
STEP 2:
In portal/includes/functions.php
FIND
if (($text_length != 0) && (strlen($len_check) > $text_length))
REPLACE WITH:
		if ( $blurbpos = stripos  ( $len_check, '[blurb' )) {
			$row['post_text'] = substr  ( $len_check, 0, $blurbpos );
			$posts[$i]['striped'] = true;
		if (($text_length != 0) && (strlen($len_check) > $text_length) && ($posts[$i]['striped'] != true) )
This will override the character count method (if the 'blurb' BBCode is present) and allow the news writer to choose where the summary/teaser/blurb ends by placing in the news post...
[blurb][/blurb]
So you could do something like this:
Rammstein singer Till Lindemann is reported to be in intensive care after attempts to remove a high-intensity LED from his mouth ran into complications.
[youtube]http://www.youtube.com/watch?v=YBcu8YWs7uM[/youtube]
[blurb][/blurb]
Doctors attending to his case said blah blah blah....
I've not thoroughly tested this. But it seems to work. I'm also new to Board 3 so I may have overlooked something.
