DirtyBoard 2.0
DirtyBoard 2.0
This config works for both Styles / Diese Konfiguration funktioniert für Styles: DirtyBoard 2.0
Demo
_block_config.html
<!--version $Id: _block_config.html v1.0.5 adapted by: archivar $ //-->
<!-- DEFINE $LR_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><h3 style="padding-left: 8px; padding-bottom: 2px;">' -->
<!-- DEFINE $LR_BLOCK_H_R = '</h3>' -->
<!-- DEFINE $LR_BLOCK_F_R = '<span class="corners-bottom"><span></span></span></div></div>' -->
<!-- DEFINE $C_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header" style="padding-left: 8px; padding-bottom: 2px;"><dl class="icon">' -->
<!-- DEFINE $C_BLOCK_H_R = '</dl></li></ul>' -->
<!-- DEFINE $C_BLOCK_F_R = '<span class="corners-bottom"><span></span></span></div></div>' -->
no
Reason: Blockabstand / Block distance - <br style="clear:both" /> - entfernt / away
