Style-Version: 1.6.2
phpBB-Version: 3.0.7
Board3Portal Version: 1.0.4 / 1.0.5 / 1.0.6
Style Download: http://www.icyphoenix.com/styles/styles ... _id=phpbb3
Portal Demo Black Pearl: http://area51.mikevil.de/portal.php?style=3
Portal Demo Rainbow Pearl: http://area51.mikevil.de/portal.php?style=72
- [+] ENGLISH
- This Guide is written for Black Pearl, but it works for Rainbow Pearl. If you want to use this Guide for Rainbow Pearl you just have to replace "black_pearl" with the Name of your Style in this Guide.
to: styles/black_pearl/template/portal/*.*
to: styles/black_pearl/theme/images/portal/*.*
open: styles/black_pearl/template/breadcrumbs.html
<a href="{U_INDEX}">{L_INDEX}</a>open: styles/black_pearl/template/breadcrumbs_footer.htmlCode: Select all
<a href="{U_INDEX}">{L_INDEX}</a>open: styles/black_pearl/template/breadcrumbs_pages.htmlCode: Select all
<a href="{U_INDEX}">{L_INDEX}</a>open: styles/black_pearl/template/menu_block.htmlCode: Select all
<a href="{U_INDEX}">{L_FORUM}</a>open: styles/black_pearl/template/overall_header.htmlCode: Select all
<!-- IF U_PORTAL --><a href="{U_PORTAL}">{L_PORTAL}</a> <img src="{T_THEME_PATH}/images/menu_sep.png" alt="" /> <!-- ENDIF -->
<!-- INCLUDE menu_block.html -->
Tip: Add these lines on a new blank line after the preceding line(s) to find.open: styles/black_pearl/template/portal/_block_config.htmlCode: Select all
_block_config.html for black_pearl
open: styles/rainbow_pearl/template/portal/_block_config.html
_block_config.html for rainbow_pearl
- [+] DEUTSCH
- Diese Anleitung wurde für Black Pearl geschrieben, funktioniert aber auch für Rainbow Pearl.
Wenn ihr diese Anleitung für Rainbow Pearl nutzen wollt, müsst ihr einfach "black_pearl" in diese Anleitung mit dem Namen eures Styles ersetzen.
Kopiere: root/styles/subsilver2/template/portal/*.*
nach: styles/black_pearl/template/portal/*.*
Kopiere: root/styles/subsilver2/theme/images/portal/*.*
nach: styles/black_pearl/theme/images/portal/*.*
Öffne: styles/black_pearl/template/breadcrumbs.html
<a href="{U_INDEX}">{L_INDEX}</a>Öffne: styles/black_pearl/template/breadcrumbs_footer.htmlCode: Select all
<a href="{U_INDEX}">{L_INDEX}</a>Öffne: styles/black_pearl/template/breadcrumbs_pages.htmlCode: Select all
<a href="{U_INDEX}">{L_INDEX}</a>Öffne: styles/black_pearl/template/menu_block.htmlCode: Select all
<a href="{U_INDEX}">{L_FORUM}</a>Öffne: styles/black_pearl/template/overall_header.htmlCode: Select all
Hinweis: Diese Zeile(n) werden in einer neuen Zeile nach den/der gerade gesuchten eingefügt.Öffne: styles/black_pearl/template/portal/_block_config.htmlCode: Select all
Öffne: styles/rainbow_pearl/template/portal/_block_config.html
