Your Portal Version: 1.0.5
Boardlink: http://www.declutteratyourservice.com
New install
I have installed the board according to instructions. I have uninstalled and reinstalled. I have triple checked includes ensuring al edits were correct
I continue to get a General Error. All files have been uploaded correctly.
General Error
SQL ERROR [ mysql4 ]
Duplicate entry '4-118' for key 1 [1062]
SQL
INSERT INTO phpbb_acl_roles_data (role_id, auth_option_id, auth_setting) VALUES (4, '118', 1)
BACKTRACE
FILE: includes/db/mysql.php
LINE: 174
CALL: dbal_mysql->sql_error()
FILE: install/install_install.php
LINE: 258
CALL: dbal_mysql->sql_query()
LINE: 73
CALL: install_install->load_schema()
FILE: install/index.php
LINE: 279
CALL: install_install->main()
LINE: 56
CALL: module->load()
General Error on Installation
- phpBB.com User: brandy
Re: General Error on Installation
Guess what, my friend the search has returned some information to me: viewtopic.php?f=10&t=3461&hilit=Duplicate+entry
Just replace the 119 with 118 in the Query.
Dear Marc:
Since this request, I deleted everything and started over. My new General Error is as follows:
General Error
Table 'declu0_declutter12.phpbb_portal_config' doesn't exist [1146]
I checked the includes/constant.php file, everything is where it should be. Should I use the same resolution for this or is there another resolution that you can point me to.
Thank you
General Error
Thank you
Did you run the installer again?
Ok....I must admit, I'm embarassed
. I did not run the install again. I just ran it and it's up and running.
Thank you
Thank you
