wintstar
Posts: 45 Joined: 24. March 2009 14:35
phpBB.de User: wintstar
phpBB.com User: wintstar
Post
by wintstar » 12. July 2010 09:53
Hab in meinem Forum das User Menü in die Portal Mitte gesetzt, soweit funktioniert es. Aber wie bekomme ich den User Avatar und Rank rechts neben das Menü?
root/styles/prosilver/template/portal/block/user_menu.html
<!--version $Id: user_menu.html 596 2009-12-25 13:02:46Z marc1706 $ //-->
{$LR_BLOCK_H_L}<!-- IF $S_BLOCK_ICON --><img src="{T_THEME_PATH}/images/portal/portal_user.png" width="16" height="16" alt="" /> <!-- ENDIF -->{L_USER_MENU}{$LR_BLOCK_H_R}
<a href="{U_VIEW_PROFILE}"><!-- IF B3P_USER_COLOR --><span style="color: {B3P_USER_COLOR}; font-weight: bold;"><!-- ELSE --><span><!-- ENDIF -->{B3P_USERNAME}</span></a><br />
<!-- IF B3P_AVATAR_IMG -->
<a href="{U_PROFILE}">{B3P_AVATAR_IMG}</a>
<!-- ELSEIF $NO_AVATAR_IMG -->
<a href="{U_PROFILE}"><img src="{T_THEME_PATH}{$NO_AVATAR_IMG}" alt="" /></a>
<!-- IF B3P_RANK_TITLE --><br /><span class="gensmall">{B3P_RANK_TITLE}</span><!-- ENDIF -->
<!-- IF B3P_RANK_IMG --><br />{B3P_RANK_IMG}<!-- ENDIF -->
<hr class="dashed" />
<div class="portal-navigation">
<div class="menutitle">{L_M_UMENU}</div>
<ul>
<!-- IF S_DISPLAY_SEARCH -->
<li><a href="{U_NEW_POSTS}">{L_NEW_POSTS}</a></li>
<li><a href="{U_UNREAD_POSTS}">{L_UNREAD_POSTS}</a></li>
<li><a href="{U_SELF_POSTS}">{L_SELF_POSTS}</a></li>
<!-- IF U_UM_BOOKMARKS -->
<li><a href="{U_UM_BOOKMARKS}">{L_UM_BOOKMARKS}</a></li>
<li><a href="{U_UM_MAIN_SUBSCRIBED}">{L_UM_MAIN_SUBSCRIBED}</a></li>
<!-- IF S_DISPLAY_PM -->
<li><a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}</a></li>
<li><a href="{U_PROFILE}">{L_PROFILE}</a></li>
<!-- IF U_MCP -->
<li><a href="{U_MCP}">{L_MCP}</a></li>
<!-- IF U_ACP -->
<li><a href="{U_ACP}">{L_M_ACP}</a></li>
<li><a href="{U_LOGIN_LOGOUT}">{L_LOGIN_LOGOUT}</a></li>
Danke
Stephan
Posts: 1963 Joined: 19. April 2009 21:34
Post
by archivar » 13. July 2010 19:58
Versuch mal das hier:
tausche den Inhalt gegen diesen in root/styles/prosilver/template/portal/block/user_menu.html:
<div style="text-align: center;"><span style="float: right;">
<!-- IF B3P_RANK_IMG --><br />{B3P_RANK_IMG}<!-- ENDIF --></span>
<div class="portal-navigation"><span style="float: left;">
<div class="menutitle">{L_M_MENU}</div>
<ul>
<!-- IF U_MCP -->
<!-- IF U_ACP -->
</ul></span>
wintstar
Post
by wintstar » 13. July 2010 20:45
Danke, funzt super
Stephan
Posts: 2504 Joined: 17. July 2008 21:08
Post
by Marc » 21. July 2010 22:30
Ich verschiebe das Thema mal in das Styles Support Forum, da es da besser passt.
