Your Portal Version: 1.0.5
Boardlink: http://classicguitare.com/portal.php
Update
I tried uninstalled portal to install it again but I can't install it, I have only the option that allows me to uninstall
Thanks !
Thanks !
SQL ERROR [ mysqli ]
Incorrect key file for table '/tmp/#sql_64f0_0.MYI'; try to repair it [126]
SQL
SELECT * FROM phpbb3_users WHERE user_type <> 2 AND user_type <> 1 ORDER BY RAND() LIMIT 1
BACKTRACE
FILE: includes/db/mysqli.php
LINE: 163
CALL: dbal->sql_error()
LINE: 205
FILE: includes/db/dbal.php
LINE: 170
FILE: portal/block/random_member.php
LINE: 46
CALL: dbal->sql_query_limit()
ERROR Incorrect key file for table '/tmp/#sql_64f0_0.MYI';
Re: ERROR Incorrect key file for table '/tmp/#sql_64f0_0.M
Seems to me like your database is corrupted. Try asking your hoster if they know what to do.
