Portalview conflict with mChat
Moderator: Dyo
- phpBB.com User: ReconMarine
http://www.forums.constructionjobsolutions.com
The forum was running perfect and portalview operated as it should. I installed mChat and the following issues have happened:
1. the custom page says it is disabled when you try to open it even though it is in fact NOT disabled in the configuration page.
2. the mchat has interfered with my portal being displayed on ALL pages of my forums, since I added the mchat, my portalview mod has stopped working properly.
3. the refresh time is not working, the time does not count down and the chat does not refresh.
4. the chat page does not show up on the index page, it only shows the place where it would be and a title link, however the timer does refresh, any clue about that?
Thanks again so much
I know the mChat is not yours, but I thought you might be able to tell me where the conflict is at between the two.
Thanks bro
Thanks bro
Re: Portalview conflict with mChat
Please enable debug in your config.php.
debug or debug_extra?
debug has been activated
And now error appears?
I would really suggest you ask the author of mChat. Have you already checked if you did all edits correctly?
Yes RM and I have been talking about it since yesterday.
Also what error, and where would I be looking for it? because I did not see where enabling the debug did anything.
amazing,......
He claims it is your stuff that is breaking his stuff.
You claim it is his stuff breaking your stuff.......
Toyota, and British Patrolium.....
I just want my website to work right again. I do not care who's fault it was, or was not.
All I did was ask for someone with a better understanding of the code to look at it and see if they recognized where the conflict was.
Did you use my instructions on how to integrate mChat into the Portal?
If yes, open portal/block/additional_blocks.php
Find:
Replace with:
Find:
define('MCHAT_INCLUDE', true);
$mchat_include_index = true;
include($phpbb_root_path . 'mchat.' . $phpEx);
if(!defined('MCHAT_INCLUDE'))
if(!function_exists('mchat_obtain_guest_count'))
I did that brother,...
I am done with it, and have removed it. I will find an alternative solution.
Thanks anyway, but this has gone on for 48 hours, and that forum needs to be active and operational.
Semper Fi
Semper Fi
Well I can tell you one thing. I tested mChat with Board3 Portal 1.0.5, phpBB 3.0.7-PL1 and the Portalview MOD and guess what? It worked without any issues.
I don't know what you did, but I guess it is either some other MOD that interferes or you have some bad edits in your phpBB3 installation.
Anyhow, I can understand if you want your board to be live again after 48 hours.
After a clean install and reinstall EVERYTHING works, except when I do the "additional blocks" edit. Once I perform that edit, it kills the website again, and leaves that initial error I posted.
When i remove that edit,......the error vanishes and the board works.
RM
Call to a member function get() on a non-object in /home/conjobs/forums.constructionjobsolutions.com/mchat.php on line 35
RM
Marc?
RM
RM
I have the same problem, and i hope marc will fix it
viewtopic.php?f=31&t=3299&p=23932#p23923
If you want a quick&dirty, just comment out line 35 and 48 in mchat.php
See in my last post.
Greets Kolja
Greets Kolja
LOL!kolja wrote:Hi
I have the same problem, and i hope marc will fix it![]()
If you want a quick&dirty, just comment out line 35 and 48 in mchat.php![]()
Greets Kolja
I wish I could read that thread....... haha.
Thanks for the link though.
RM
Sorry
But there is no solution until now
If there is one, i write it here (in english)
Kolja
Kolja
Google translate does a pretty good job in translating the threads. http://translate.google.com/#de|en|ReconMarine wrote:LOL!kolja wrote:Hi
Greets Kolja
RM
Copy that thread's URL into the translate box.
It works pretty good.
