Your Portal Version: 1.0.5
Boardlink: http://l2dragonriders.atw.hu/
Hi there
I have installed a new forum, and get this interesting mod. I really like it, and get some options changed to fit my needs. Now i want to make the portal.php onload instead of the basic index.php. I changed my .htacces to this :
"<Files "config.php">
Order Allow,Deny
Deny from All
</Files>
<Files "common.php">
Order Allow,Deny
Deny from All
</Files>
DirectoryIndex portal.php"
But the index.php loads in every time i open the site. Is it a good and/or standard resolution to edit the index.php with the content of portal.php ?
Creative
Portal.php instead of Index.php
Re: Portal.php instead of Index.php
try putting
and see if that works. if not then your host might be restricting custom .htaccess and forcing there own to load banner at the top of all your pages
DirectoryIndex portal.php index.php
Doesn't work
Any idea how to make it work?
If it doesn't work that way, contact your hoster. They should be able to control this.
