Voting on Portal Poll Block not registered
smartcooky
Post by smartcooky »
Your Portal Version: ???
After setting up a Poll and displaying it on the Portal, users can see the Poll block, and can go through the actions of voting, but when they click Submit, the page reloads and the vote is not registered. They can click on the "View Topic" link and vote there successfully
I have checked that all permissions are correct.
The "Allow voting:" radio button in the ACP Portal > Poll section is set to "Yes".
Am I doing something wrong or is there an issue with this?
smartcooky
Re: Voting on Portal Poll Block not registered
Anyone?
I just tested it on Board3 Portal 1.0.5 and it works without any issues. What other MODs do you have installed?
melian
Post by melian »
I've the exact same issue, the only difference is that the votes were working but not anymore. I may have modified something but I don't know what. I need to know if OP solved his problem, but I can't PM him. Any help?
melian wrote:I've the exact same issue, the only difference is that the votes were working but not anymore. I may have modified something but I don't know what. I need to know if OP solved his problem, but I can't PM him. Any help?
blame are the permissions.
Check the permissions and change them.
melian
Post by melian »
archivar wrote: Hi,
Which permissions? I just updated to 1.0.6 and the problem is still there and I haven't touched any options in the portal.
Everybody is able to vote, the issue must come from a modification I made but I can find the source. Why would the votes not be registered? Any ideas?
melian
Post by melian »
I solved my problem.
I added this in .htaccess to cut portal.php from the URL and it caused a conflict with the poll.
# PORTAL
RewriteRule ^forum/portal\.php$ http://www.psu-odyssey.com/ [QSA,L,R=301]
