[php debug] errors
skeksis
phpBB.com User: Skeksis
[php debug] errors
Post by skeksis »
Your Portal Version: 1.0.5
Boardlink: http://skeksiswow.dyndns.org/forums/portal.php
PHP Version: 5.3.1
MySQL Version: 5.1.41 + PBXT engine
Only had PHPbb3.06 and PBWoW Mod/Theme installed and it worked fine. Wanted to add Boards3 and getting multiple errors.
Multiple Reinstallations and clearing mysql tables each time.
Hello,
I have PHPBB3.06 installed along with Automod, Mod Version Check, PBWoW mod/themes and hopefully soon Board3 Portal. The first time I tried installing Board3, I had already had PHPbb and PBwow installed, then later on the Automod, Board3 then the Mod Version Check. Needless to say, it was sloppy installs and got errors. So I went ahead and did a clean slate install, deleted everything, cleared my tables in MySQL and started fresh. I started out installing PHPBB 3.06. Then the Automod, then the Mod Version Check, the Board3 Portal, then PBwow. Everything installed without errors according to Automod. I then went to http://skeksiswow.dyndns.org/forums/install/index.php to finish installing Board3 Portal, went in and deleted the install folder when it was completed. I then installed all the styles/themes from PBwow. I then clicked on system to setup the mods for pbwow and got the following message:
General Error
Module not accessible
Please notify the board administrator or webmaster: skeksisnv@gmail.com
Thought that was strange and went ahead to see if I can go into the .MODS tab to check out the options and settings for Board3 Portals and got the following message:
[phpBB Debug] PHP Notice: in file /portal/includes/functions_version_check.php  on line 38: include(./mods/board3_portal_check_version.php) [function.include]: failed to open stream: No such file or directory
[phpBB Debug] PHP Notice: in file /portal/includes/functions_version_check.php on line 38: include() [function.include]: Failed opening './mods/board3_portal_check_version.php' for inclusion (include_path='.;C:/Darkrulerz/xampplite/php/PEAR')
[phpBB Debug] PHP Notice: in file /portal/includes/functions_version_check.php on line 42: call_user_func() expects parameter 1 to be a valid callback, class 'board3_portal_check_version' not found
[phpBB Debug] PHP Notice: in file /adm/index.php on line 150: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3494)
[phpBB Debug] PHP Notice: in file /adm/index.php on line 152: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3494)
[phpBB Debug] PHP Notice: in file /adm/index.php on line 153: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3494)
[phpBB Debug] PHP Notice: in file /adm/index.php on line 154: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3494)
Administration Control Panel
Admin index • Board index
Skip to content
    * General
    * Forums
    * Posting
    * Users and Groups
    * Permissions
    * Styles
    * Maintenance
    * System
    * .MODs
    * AutoMOD
You are logged in as:
skeksis [ Logout ][ ACP Logout ]
    * Portal
    * General settings
    * News
    * Global announcements
    * Welcome message
    * Recent topics
    * Wordgraph
    * Paypal donations
    * Attachments
    * Newest members
    * Poll
    * Recent bots
    * Peak posters
    * Mini calendar
    * Custom block
    * Links
    * Friends
    * Birthdays
Portal administration
Thank you for choosing Board3 Portal! This is where you can manage your portal page. The options below let you customize the various general settings. The links on the left-hand side allow you to customize in detail every aspect of your portal experience.
MOD Version Check
is not up to date
Current Version
Latest Version
    Version server could not be contacted
Download Latest Version
    Download Version server could not be contacted
Release Announcement
    Annoucement Topic
General settings
Enable Portal:
Turns the whole portal on or off.
    Yes No
Enable left column:
Switch to no if you wish to turn off the left column
    Yes No
Enable right column:
Switch to no if you wish to turn off the right column
    Yes No
Versioncheck on Portal:
    Yes No
Advanced statistics block:
Display this block on the portal.
    Yes No
Search block:
    Yes No
Leaders / Team block:
    Yes No
Extended Leaders / Team:
The "Leaders / Team" block must be activated in order to display this extended block.
The standard block lists all admins/mods, while the extended block includes all non-hidden groups with a legend.
    Yes No
Clock block:
    Yes No
Link us block:
    Yes No
Random member block:
    Yes No
Forum Index (Forum list):
    Yes No
Who is online?:
    Yes No
Styleswitcher:
Please note: If "Override user style:" in the board settings is set to "Yes", this block will not be displayed, regardless of this setting.
    Yes No
Main menu:
    Yes No
phpBB menu:
Display the phpBB Header on the portal.
    Yes No
User menu / Login box:
    Yes No
Left and right column width settings
Width of the left column:
Change the width of the left column in pixels; recommended value is 180
Width of the right column:
Change the width of the right column in pixels; recommended value is 180
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
Not sure, what to do at this point. I will clean it all out again, and try to reinstall again tomorrow. Its getting late right now. But any help would be greatly appreciated.
I thank you,
Skeksis (Gary)[/i]
Re: [php debug] errors
Please upload all files as directed by the install instructions.
