http://finalascension.pixelwarrior.org/portal.php
I want to remove: "Portal » Board index" (the breadcrumb part) only for my portal
Any ideas?
Removing breadcrumbs from the portal
Re: Removing breadcrumbs from the portal
I want to remove the breadcrumbs from the portal so it looks cleaner
This is my board:
It is based on subsilver2 style.
I found a way to do it but I fear I might have messed up something else. In order to remove it I had to change this IF statement from overall_header.html
To:
<!-- IF not $S_IN_PORTAL -->
I have no idea what S_DISPLAY_PHPBB_MENU means. Anyone care to explain? Also should I be worried I made this change?
This is my board:
To:
Set this to no in the ACP:
phpBB menu:
Display the phpBB Header on the portal.
And undo the changes you just mentioned.
phpBB menu:
If I do that it also takes away the menu above the breadcrumbs.
Is there any way I can stop this function from doing this?
Link to my board:
EDIT:
Found the fix! Thanks for your help sir! =)
Link to my board:
EDIT:
