Boardlink: http://www.cusemen.com/in/portal.php
PHP Version: 3.0.7
I would like to add the Viewonline_body.html to the Portal page.
I have added the mchat to Portal, no problem, but I cant seem to figure out how to add the viewonline_body.html to the center block right above the chat box.
I know I need: <!-- INCLUDE viewonline_body.html --> to the portal_center.html, but I dont understand or know how to use the "if's". I follow instructions well, and that is why my board is where it is.
Please let me know if you can help.
Thank you very much!
Robby
						Adding Viewonline to Portal Center Block
Re: Adding Viewonline to Portal Center Block
That won't work, since the viewonline.php creates a lot of variables for that page, which the portal is not able to do.
Understood, thanks.
What if I wanted to move the "Who is Online" block at the bottom to the top center of the page? Would that be possible?
Move this in styles/*yourstyle*/template/portal/portal_center.html:
<!-- IF S_DISPLAY_ONLINE_PORTAL_LIST and S_DISPLAY_ONLINE_LIST -->
	<!-- INCLUDE portal/block/whois_online.html -->
<!-- ENDIF -->Re: Adding Viewonline to Portal Center Block
I almost thought it didnt work, But i refreshed the Template and it is right where I want. Thank you for your help!
