Install on phpBB3 with Rainbow Pearl Style
dutchie
- phpBB.com User: largerth
Your Portal Version: 1.0.5
Boardlink: http://www.larger-than-life.org/xforum
nothing YET
writing a new topic here
Is there anything I need to know when my board uses the Rainbow Pearl style?!
Should every file that is uploaded to subsilver theme now be uploaded to Rainbow Pearl folders? (I de-activated all other styles...)
Any tips I should know about?!?
( Am really a noob...)
nothing YET
dutchie
Re: Install on phpBB3 with Rainbow Pearl Style
OK, I'm not getting a reply here, so I'll rephrase that question...
I want to install the portal on a PhpBB3 board with Rainbow Pearl style installed. When you check your installation, you will find that the files in the Rainbow Pearl style you must edit are different from the Prosilver or Subsilver2 files.
My question. what are the edits to the Rainbow Pearl style?!? Which files and What do I need to edit?
Your style is based on subsilver2.
That you can also take for your style.:
viewtopic.php?f=44&t=2864
Demo: http://area51.mikevil.de/portal.php?style=72
You can try this install guide, since these Styles are from the same Autor, and the code is mainly the same..
If it doesnt work, make a request here: viewforum.php?f=39
dutchie
Thank you very much Mike, your tip was very helpful. I got the portal to work, no problem.
There's just one tiny problem: in the Who Is Online block, the icon is missing (shows up as a red "X").
Which file should go where to get it working? Thanks in advance for your help!
Open styles/*yourstyle*/template/portal/block/whois_online.html
Do this twice:
Find:
Replace with:
Do this twice:
Find:
{T_THEME_PATH}{$WHOS_IMAGES}Code: Select all
{T_THEME_PATH}/images/online.png-
dutchie
Alas, no Icon, just a little text saying Who is online....
Refresh your template cache.
dutchie
Oops. thanks!!
Now it works!
Now it works!
dutchie
All those who have been posting in this thread and helped me installing the portal on my site:
THANK YOU ALL VERY MUCH!!!
