Use a custom style?
DeadandWalking
Use a custom style?
Post by DeadandWalking »
Boardlink: http://www.deadandwalking.com/zombies
Nothing Yet
I've just installed the portal to my root directory. However I had to have prosilver installed when my previous theme was a custom one name sliced. How can I get this theme to work with the portal?
Thank You!
Re: Use a custom style?
As sliced is based on subsilver2, try doing the subsilver2 edits on your style.
DeadandWalking
Thanks for the fast reply!
Just one thing, where is a link to the subsilver edits? I only got prosilver with my readme. :)
EDIT: Never mind. I found it. Thank you. I'll repost if I get any problems :)
DeadandWalking
Hi again,
When using sliced I now get this: "Parse error: syntax error, unexpected $end in /home/deadandw/public_html/zombies/cache/tpl_sliced_overall_header.html.php on line 205"
I don't suppose anyone knows how to fix this?
Thank you
You have done a wrong edit in your overall_header.html
Find it, or replace ot with the original. Here you can make a request ;)
