upgrade my portal v1.0.4 to v.1.0.5
EA7351
Post by EA7351 »
Boardlink: http://www.tomtomgps.net
PHP Version: phpbb v3.0.6
I need help understanding how I have to upgrade my portal v1.0.4 to v.1.0.5
We also want to know if the upgrade to v1.0.5 is maintained by the Spanish idiom v1.0.4.
Thank you very much
Re: upgrade my portal v1.0.4 to v.1.0.5
There are update instructions in the contrib folder within the package. And your second question... i dont know wxactly what you mean... Do you ask for a spanish translation for 1.0.5?
Yes, I think he is asking for the spanish translation, and I hope they will be available soon. If not, I'll do them myself.
Thresherinc
phpBB.com User: Thresherinc
Post by Thresherinc »
I tried to update from 1.0.4 to 1.0.5 I downloaded the package, moved the update_104_to_105 directory to the store/mods directory and tried to do an install and it fails due to board3 already being installed.
Maybe I'm missing a vital clue.
It's not 100% a problem for me as I shall be doing a fresh install very soon but a readme in the base directory with clear instructions would reduce support requests.
First of, AutoMOD is currently just for testing purposes.
I think you need to copy the whole archive and then you should be able to somehow choose the update instructions. It's probably better if you ask at phpbb.com or the spanisch support site.
