Installation problem
xTz
Post by xTz »
Your Portal Version: 1.0.4
MODs installed: Yes, announcement center.
Boardlink: http://techn0.eu
Just installed board3 Portal
Uninstall, then install again, but couldn't uninstall at all.
Ok, I've installed board3 Portal. Then, when I went to the control panel, I've seen its settings in the column on the left, but when I clicked ANY of them - nothing, just only a white page. So I said - no problems, I will just reinstall. Run /install/index.php, select UNINSTALL, but it does nothing. It says that it is uninstalled, but I can still open the link, the DB tables are still there, everything is working as it is still installed. Only the portal disappeared from the ACP. When I open /install/index.php, it again detects that it is installed and I can select uninstall again, but it does nothing again... if I open for the 3rd time /install/index.php - it shows as installed again... and so on. So, as a final question: what should I do to get it installed and working :roll:
Portal url: http://techn0.eu/portal.php
Board url: http://techn0.eu/index.php
P.S.: I restored from a DB backup, made just before I tried to uninstall, so I am back to baste 1: board3 portal is installed, but whenever I click on any of its link on the ACP page - I just get white screen.
Re: Installation problem
What editor did you use the edit your files? The editor must be able to save files as UTF-8 without BOM. The normal Windows editor is not able to do that.
xTz
Post by xTz »
You mean, to edit the files on the server? GNU NANO.
I think GNU Nano is able to handle UTF8, but I don't think it is able to save files as UTF8 without BOM.
Maybe this topic helps you:
http://www.phpbb.com/community/viewtopi ... &t=1669305
