Getting this code to display in small custom block
Foxy
phpBB.de User: Foxy
phpBB.com User: fujcube
Post by Foxy »
Your Portal Version: 1.0.4
Boardlink: http://www.border-forums.com
Nothing
Various editing of code, adding BB tags etc etc.
I am trying to get this code to display properly in the small custom block on my portal page:
<iframe src="http://www.worldcommunitygrid.org/getDy ... cial=false" frameborder="0" name="di" scrolling="no" width="405px" height="145px"></iframe>
The code should display an image with some statistics from my team that I created on the World Community Grid.
Regards, fujcube
Re: Getting this code to display in small custom block
First of, it doesn't fit in the small custom block, just in the center custom block.
Second of, it does work. Just enable the custom block and copy the iframe code in the codebox in the ACP. Make sure that BBCode is not enabled.
P.S: Because of the iframe, the page is not XHTML valid anymore.
Foxy
phpBB.de User: Foxy
Post by Foxy »
Thanks for the reply. I can change the 'widget' for a smaller one, the code will be similar, just a smaller image. What does this mean "Because of the iframe, the page is not XHTML valid anymore"
Someone over at phpBB.com suggested:
http://www.phpbb.com/community/viewtopi ... #p11768455
Regards
XHTML valid just means that the code is 100% correct regarding the XHTML 1.0 standard. The iframe shouldn't cause any errors.
What the user over at phpBB.com suggested, doesn't change anything, as it is still an iframe.
Foxy
phpBB.de User: Foxy
Post by Foxy »
Thank you. I changed the widget code for a smaller one did as you suggested. Now working fine.
Regards, fujcube
