Boardlink: http://www.clioclub.it
I have not modified the file htacces as instructed because my hosting service (Aruba on linux server) does not accept the string:
So to remedy the problem, after sleepless nights, I managed to partially circumvent the problem by changing htacces this:
<Files "config.php">
Order Allow, Deny
Deny from all
</ Files>
<Files "common.php">
Order Allow, Deny
Deny from all
</ Files>
RewriteEngine On
RewriteBase /
RewriteRule ^ index \. Php $ portal.php
Hello everyone,
I hope not to have been wrong section.
I ask for help for a problem installing board3 portal on phpbb3.
Both versions are the latest available.
I installed everything properly, and the portal is visible: View ---> http://www.clioclub.it
But I have a problem with the display of the forum, in practice I can not see it and are always redirected to the home of the portal.
The problem should lie on the fact that I had to edit the file and therefore not htacces mod as instructed:
Open:. Htaccess
Order Allow, Deny
Deny from all
</ Files>
Tip: Add these lines on a new blank line after the preceding line (s) to find.
Order Allow, Deny
Deny from all
</ Files>
Order Allow, Deny
Deny from all
</ Files>
RewriteEngine On
RewriteBase /
I hope that is clear and I hope that some of you can help solve the problem, I have not slept for nights and I finally go to sleep: D[/i]
