mini calendar title not showing right
mattconley2011
Post by mattconley2011 »
Your Portal Version: 1.0.4
Boardlink: http://usurpingauthority.co.cc
i modded the pbwow into the forum
My calendar title shows as { MINI_CAL_CALENDAR } instead of just Calendar
How do i go about fixing this?
Thank You
Matt
Widmo
phpBB.com User: Widmo696
Re: mini calendar title not showing right
Post by Widmo »
Upload your language files.
mattconley2011
language files?
The update instructions from v.1.0.3 to v. 1.0.4 (prosilver and subsilver2) seems to be not quite in order;)
Actually should be after / template / portal / block / stand
Best if you copy the appropriate files in the install-root folder are there just as they are distributed.
mattconley2011
i did not update, i did a whole fresh install
<!--version $Id: mini_calendar.html 481 2009-03-15 23:16:32Z Christian_N $ //-->
This is a block of 1.0.3
This is not with 1.0.4
<!--version $Id: mini_calendar.html 544 2009-09-10 12:35:25Z christian_n $ //-->
This is a block of 1.0.4
mattconley2011
Do i need to change something then? i have version 1.0.4
Is the error in prosilver?
mattconley2011
in prosilver it looks like it's suppose to look
but when i use pbwow from pbwow.com its messes up
also how do i add events to dates?
mattconley2011
i fixed it, i needed to replace min_calendar.html with the one for 1.0.4, for some reason i had the 1.0.3 version
i don't know why, but i did, thanks for your help :)
mattconley2011
how do i add events on dates?
In your styles, the blocks of 1.0.3 are
It is possible that now blocks all make mistakes.
You must fit all the blocks in the styles for 1.0.4.
mattconley2011 wrote:how do i add events on dates?
My English is bad. Can you different questions?
mattconley2011
like, when i click on a certain day, it goes to a page where it says certain things that are happening on that day
In the ACP under Portal Mod. "Settings for the mini-calendar" you can set the color for the current day.
Edit:
mattconley2011 wrote:like, when i click on a certain day, it goes to a page where it says certain things that are happening on that day
It is not possible in the calendar!
