Couple questions - updated
Boatski
Post by Boatski »
Here's my site. (Currently in the works)
http://www.superiorityguild.com
One problem fixed.
For every news post they are located within the same "block"
Example:
Now my question is - Is it possible to make each news post in its own seperate block?
I quickly photoshopped what I'm looking to achieve.
Example:
With each news post being seperated a little.
The news block doesn't seem to be lined up with the nav bar, which I couldn't seem to find where to fix this at.
Also I'm looking at the file /styles/prosilver/template/portal/blocks/news.html
I'm wanting to remove the Forum: Announcements and the bottom text Views, Comments, & Write Comments. I've deleted the lines out of the news.html file, but nothing seemed to change. Is this the correct file to be editing for it?
