Adding a custom block / einen eigenen Block hinzufügen
Bash
phpBB.de User: Bash
phpBB.com User: Bash
Re: Adding a custom block / einen eigenen Block hinzufügen
Post by Bash »
It worked!
I just left that last edit as it was.
I now have an additional block which functions the same as the news block :D
Jennifer Lynn
phpBB.de User: Jennifer Lynn
phpBB.com User: Darkravensor
Post by Jennifer Lynn »
Hi there,
My experience with phpbb has been 4 weeks so I am a beginner. I have read a lot of documentation prior to any installations and tried to understand every detail before moving forward. So far I have succesfully installed phpbb as well as the portal without any issues :) I have also read instructions and added the portal 'link' to the ACP by following a post on this forum.
My next challenge is to learn how to add custom blocks. I have read through your documentation and it indicated how to create your new file and where to add the scripting minus the 'IF' statements as those are just for the ACP and original blocks.
I will have more questions once I get started, however my first is: Is it possible to configure so the new boxes will show up in the ACP where you can input the information as needed OR do you have to put your data into your new block file? As a simpler way of phrasing the same question -- I'm looking at just duplicating what is already there and have more than just the small and centre box in the ACP. So when you go into your ACP you can turn them on and off as desired.
I apologize if the answer is on the board here somewhere. I did do a search first before posting, however if I missed it -- would you kindly re-direct me.
I appreciate your time,
Jennifer Lynn
mstaviation
phpBB.de User: mstaviation
phpBB.com User: mstaviation
Post by mstaviation »
Hello Guys,
I don`t exaclty understand something. I want to make my own custum block on the left site of the menu. So i followed the this topic : knowledge/kb_show.php?id=51
I have made my own html file : styles\subsilver2\template\portal\block\maas.html
First of, make a new file (your Block) in \styles\your_style\template\portal\block\ and call it i.e. new_block.html
Now you have to decide if this Block will be a center block or if it will be in left or right column.
Last but not least you should know, if your Style is based on prosilver or subsilver2.
but i don`t understand what i have to fill in here : ... Place your Code here ...??
left/ right Block for prosilver:
{$LR_BLOCK_H_L}Your_Block_Title{$LR_BLOCK_H_R}
Who can help me?
mstaviation
mstaviation wrote:Hello Guys,
Who can help me?
?? someone
ixl
Sponsor
phpBB.de User: IXL
phpBB.com User: IXLUKCOM
Post by ixl »
If I can help, ive just done this additional custom block, reading through the notes on the first page link. Its actually very simple. ( Im assuming im right, as I have it working for me )
Basically, unlike the default custom blocks ( small and middle ) that come with the board3 install, which can be managed via the ACP Mod tab, this "additional custom blocks" are hard coded. Which means, you enter the HTML or IFRAME,( or whatever ) code that you wish to put in your new block in that very space, over writing the words " ... Place your Code here .." with what you want to put in. You cannot change this new block from the ACP custom block admin. So whatever you had intented to put in the acp custom code box for the acp versions of the custom blocks, you need to put it in the gap as stated instead.
So just put in there after :
and before
code with the information you want to put in your new custom block. :)
Hope thats ok.
I.X.L
Just because it worked for you, doesnt mean it's right. ;)
http://WWW.TEAMGAMERS.CO.UK
diesusi
phpBB.de User: diesusi
Post by diesusi »
ich hab eine kleine Frage zu den eigenen Blöcken und zwar habe ich den Blog Mod installiert und würde gerne die neusten Blogeinträge in einem custum block anzeigen lassen.
Mein style ist prosilver und der block soll in die Mitte.
Diesen Code http://lithiumstudios.org/forum/viewtop ... 1045#p8093
habe ich zwischen den code für Mitte+prosilver gesetzt, allerdings bekomme ich nur einen leeren Block angezeigt.
Meine komplette blog_block.html sieht so aus:
    {$LR_BLOCK_H_L}&nbsp;Letzte Blogs{$LR_BLOCK_H_R}
    <!-- IF .recent_blogs -->
    <div class="post bg3" style="text-align: center;">
          <strong>{L_RECENT_BLOGS}</strong>
    <!-- BEGIN recent_blogs -->
       <div class="post bg1<!-- IF recent_blogs.S_REPORTED or recent_blogs.S_UNAPPROVED --> reported<!-- ENDIF --><!-- IF recent_blogs.S_DELETED --> deleted<!-- ENDIF -->" <!-- IF recent_blogs.POST_COLOR and not recent_blogs.S_REPORTED and not recent_blogs.S_UNAPPROVED and not recent_blogs.S_DELETED -->style="background-color: {recent_blogs.POST_COLOR}"<!-- ENDIF -->>
          <div class="postbody" style="width: 100%;">
             <!-- IF recent_blogs.S_UNAPPROVED or recent_blogs.S_REPORTED -->
                <p class="rules">
                   <!-- IF recent_blogs.S_UNAPPROVED -->{UNAPPROVED_IMG} <a href="{recent_blogs.U_APPROVE}"><strong>{L_UNAPPROVED}</strong></a><!-- ENDIF -->
                   <!-- IF recent_blogs.S_REPORTED -->{REPORTED_IMG} <a href="{recent_blogs.U_REPORT}"><strong>{L_REPORTED_SHORT}</strong></a><!-- ENDIF -->
                </p>
             <dl>
                <dt>
                   <strong><!-- IF recent_blogs.S_HAS_POLL --><img src="{T_THEME_PATH}/images/blog/icon_poll.gif" style="float: right;" alt="" /> <!-- ENDIF --><a href="{recent_blogs.U_VIEW}">{recent_blogs.TITLE}</a></strong> {L_POST_BY_AUTHOR} <strong>{recent_blogs.USER_FULL}</strong>  {L_POSTED_ON_DATE} {recent_blogs.DATE} <br />
                   <div class="content" style="width: 95%; padding: 4px;">{recent_blogs.MESSAGE}</div>
                   <!-- IF recent_blogs.S_HAS_ATTACHMENTS -->
                      <dl class="attachbox">
                         <dt>{L_ATTACHMENTS}</dt>
                      </dl>
                   <br clear="all" />
                   <div>
                      <span class="num_replies">{recent_blogs.REPLIES}</span>
                      {recent_blogs.VIEWS}
                </dt>
             </dl>
    <!-- END recent_blogs -->
Kann mir jemand sagen, was ich falsch gemacht habe?
Grüße,
susi
edit: // hat sich erledigt, danke!
Munra
Post by Munra »
Can someone give me an example of a if statement to restrict a custom block to a certain user group?
Thanks for all the other information already posted :) Its a real help.
Ben
phpBB.de User: Ben
phpBB.com User: Ben
Post by Ben »
Habe mir einen neuen Block in der mitte erstellt,ein Bild Code eingefügt.Blos bekomme ich das Bild nicht mittig es bleibt immer links.
{$C_BLOCK_H_L}<dl><dt>Willkommen</dt></dl>{$C_BLOCK_H_R}
<ul class="topiclist forums">
<li><dl>
<dd style="border-left: 0px">
<center><img src="http://s1.directupload.net/images/11011 ... "></center>
</dd>
</dl></li>
{$C_BLOCK_F_L}{$C_BLOCK_F_R}
Klappt das überhaupt oder was mache ich da falsch?
Hallo Ben,
statt dessen:
<center><img src="http://s1.directupload.net/images/110115/noyglnm2.png"></center>
nimmst Du das hier:
<div align="center">
<img src="http://s1.directupload.net/images/110115/noyglnm2.png" alt="" />
Über Google-Suche hättest Du es auch gefunden: html code bild zentrieren ;)
Ben
phpBB.de User: Ben
phpBB.com User: Ben
Post by Ben »
Stimmt,aber trotzdem DANKE !!
Michel_61
Portal Enthusiast
Post by Michel_61 »
Moin,
mal meinen allerherzlichsten Dank für dieses Snippet,
Ich hab ein Problem mit einem Subsilver Style, Black Pearl, gehabt, wo ich die Links zu den Mod's nicht im Header untergebracht bekam.
Der eigene Block war da die Lösung und genau an die Anleitung gehalten hab ich sogar MOD's die nur für Prosilver gedacht waren im Subsilver zum laufen gebracht.
Meinen Dank hierfür... :D
Grüsse Micha
Terr0r
phpBB.com User: Terr0r
Post by Terr0r »
If I install a extra block in the portal is there then a option that I can disable and eneble that block in the ACP
ixl
Sponsor
phpBB.de User: IXL
Post by ixl »
Terr0r wrote:If I install a extra block in the portal is there then a option that I can disable and eneble that block in the ACP
No. If you add manual blocks, they are only editable manually. You can enable and disable the view of them from non logged in users, but thats about all I believe.
I.X.L
Joschi
Post by Joschi »
ich habe einen neuen Block (unter 1.0.6) nach der BEschreibung eingebunden:
{$LR_BLOCK_H_L}<span style="float: left"><img src="{T_THEME_PATH}/images/portal/portal_stats.png" width="16px" height="16px" alt="" /> neuer Block {$LR_BLOCK_H_R}
   <tr class="row1">
      <td style="text-align:center;">
..HIER KOMMT TEXT REIN...
    <a href="http://www.meinehomepage.de/" onclick="window.open(this.href); return false;" title="xxxxxx">
    <img src="http://www.meinehomepage/forum/bilder/bild_xxx_150.jpg" width="150" height="50" alt="xxxxx" /></a>
Der Block wird angezeigt aber der Inhalt/die Grafik nicht- es wird nur das "..HIER KOMMT TEXT REIN..." angezeigt.
was ist falsch??
Danke
Hallo Joschi,
versuche es mal damit:
   <tr class="row1">
	  <div class="postbody">
